Question about Cub Cadet Garden
Cub cadet 1027 with Briggs 9 hp engine. Belt
Cub cadet 1027 with Briggs 9 hp engine. Belt broke,chaned both but now wont start, turnover or make any sound when key is turned. At same time as changing the belt also tipped mower to side to attempt to remove blade for sharpening. Check battery, fuse, plug, gas, brake apears to engage. Have I tripped a safety switch or something changing the belt, tipping it or something else?
  • anaggatz Jun 06, 2010
    engire ran after belt broke before replacement put on.
  • anaggatz Jun 09, 2010
    Thank you for the jump option. It was the solenoid.
  • 2,272 Answers
You need to check all the pulleys for belt alignment. Also check if a pulley is bent together in one spot and making the belt jump. start with the basics, replace your fuel filter, check the fuel pump pressure, check the fuel pump volume, and check your spark quality. There May be a Bad Safety Switch, the Starter May be Bad or the Solenoid May be Bad. The Large Post on the Solenoid that has the Battery Cable from the Battery is Always Hot. The Battery Post on the Solenoid that hass the Battery Cable to the Starter is Hot Only When the Ign Switch is Turned to the Spring Loaded Start Position. The Small Post on the Solenoid Gets Current fron the Ign Switch to Engage the Solenoid. Here are the Starter Solenoid Diagnostic Instructions: Use your Jumper Cable Set and Attach the Positive Lead Onto the Positive Post of the Battery (make sure the Battery is Fully Charged or is a New Battery). Now Firmly Touch the Large Post on the Starter. If the Starter Does Not Turn, then the Starter is Bad. If the Starter Turns the Engine Properly, Then Check the Solenoid. Firmly Touch the Small Post at the Base of the Solenoid. If The Starter Does Not Turn and the Solenoid Clicks, Then the Solenoid is Bad. Unplug the Safety Switch from the Harness.
thanks.
Posted on Jun 06, 2010
    President:
  • 1,469 Answers
Hi,when last did you really serviced or used it last?,
This is what to do , If you take it for servicing and after servicing, if no solution, that means the engine is too old to work again and the engine is due for change.
If it is a new engine, i would advice you take it back if it is on guarantee. i think they can replace it with another.
Take care.
I got a 50in cub cadet ZT came with a Briggs on it . I'm putting a 22 hp Kohler command motor on it. I need the specs for all the wiring from the Kolher command motor to the Cub Cadet
Look at the wiring color codes and their purpose in the Briggs manual, Compare to the wiring color codes and purpose for the Kohler engine in manual, connect accordingly.
Jun 15, 2015 | Cub Cadet Garden
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
Cub cadet troubleshooting Have a 2005 cub cadet 5254. Starts fine and stays running,however when put into gear it won't move. Any clues as to what it could be.
can't say for sure but it might just be a belt broke or out
of hydrolic fluid depends of type of transmission.
Oct 06, 2013 | Garden
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
Cub cadet 22 hp zeroturn wont start after storing for winter. Replaced battery, it looks like its not getting enough power to start. It will not turnover all the way.
charge and test the battery. the battery may be no good after sitting all winter and may need to be replaced.
Feb 21, 2013 | Garden
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
May 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Garden Logo
192 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
