Question about KitchenAid K45SS Classic Stand Mixer
Kitchen aid classic mixer,mixing head comes down to far
  • 185 Answers
Flip head up; and, there is a adjust screw underneath. turn screw out ccw to raise head.
Posted on Aug 31, 2010
The screw underneath the head of my kitchen aid mixer is tight, but the head is still wobbling. It isn't a beater adjustment--I already tried that. The head of the mixer is tilted forward a bit--in
When you have the head lifted up the screw you can see in there from the front in the middle by the hinge is the head height adjuster. You need to set the height correctly now so that FLAT PADDLE just clears the bowl. Unscrew it anti clockwise to raise the head. Once that is done turn the machine upside down on a towel and check that the locking screw on the hinge pin is tight, it\'s right up inside the pedestal.
Aug 08, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
My kitchen-aid stand mixer won't spin when turned off. When on and mixing, the motor starts to "dog", or slow down, when it's mixing something as easy as cookie dough.
If the motor itself is slowing down, that is one thing. However, if you mean by "dog" that there is what sounds as if a gear is slipping then the solution is straight forward. The worm (follower) gear needs to be replaced.
There are videos on the net which show how to do this and the Service Manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mar 21, 2014 | KitchenAid K45SS Classic Stand Mixer
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
Kitchen Aid stand mixer head doesn't lock down and wobbles
You need to do a couple of strokes with a rat tail file at a 30 degree angle at the top of the slot the head lock engages into. You will need to remove the hinge pin to do this. A Kitchen Aid agent will have done plenty of then so it won't cost an arm and a leg to get it sorted.
Nov 17, 2012 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid mixer leans forward too far, causing the mixing attachments to rub on the bottom of the bowl instead of rotating just above the bottom of the bowl. how do i fix it?
Is this for a "tilt neck model? If so, the manual suggests that there is a small screw in between the base stand and the "neck" of the mixer. You should be able to screw it in or out to adjust it. Good luck!
Oct 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid mixer makes a sqealing sound. Can
yes it can. just above the rotating head there is 5 screws that can com lose and start rubbing the head as i turns. there is a pin in the the bottom of the spinning head and the only way to get to the screws is to push that pin out and slide it off. there is a few ways to fix the screws from coming out. one is to buy lock washers. these won't allow it to back spin the screws. but you will have to use a file to shave the part of the washers that sticks out. this is the sure way that it won't come out. or you can put lock tite glue to lock them in, but if you need to ever get the screws out again you will break them. before you put the rotating head back on you will need to clean the old grease out because it has metal shavings in it. them replace with a gear grease. just small dabs should do. to much will throw it into the mixing bowl. just put it back together and your good to go.
Feb 16, 2010 | KitchenAid K45SS Classic Stand Mixer
My kitchen aid mixer makes a clicking sound when it is on and will not mix properly. It spins, but sounds bad.
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Mar 11, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid 300 watt counter mixer model ksm90
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Kitchen aid mixer
Tilt the head back and remove your cardboard shim. You should see a screw head. Turning this screw adjusts the beater/bowl clearence.
Apr 13, 2017 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid K45SS Classic Stand Mixer Logo
80 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
