Question about As Seen On TV Easy Stitch Mechanical Sewing Machine
I purchased an easy stitcher from Target, I attempted to mend a hem, when I placed the garment in the machine and pressed the foot petal, the needle just goes up and down, it's not advancing through the fabric, I don't know whats wrong with the machine or me?
  • peachskymomm Jun 06, 2010
    Thank you so much, your reply was very helpful and very imformative
  • 713 Answers
Hi,i think you should check the threading of the machine,Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.Also ensure to check the fitting of the bobbin into the bobbin case,if the bobbin settings and the threading of the machine are not properly done,you will be experiencing the problem you are encountering right now,
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Thanks and take care
Posted on Jun 06, 2010
ELNA 540 Experience how do i use the foot marked with an R? What is the settings for a rollstitch?
The foot labeled R is the buttonhole foot. Raise the machine needle and put the foot on the machine. Pull the button holder to the back of the machine and place the button for the garment in holder. Push the button holder to close it against the button. For thick buttons, you may want a slightly larger space for the button. Just pull back the holder a fraction. Push the button hole lever down as far as it will go. (The lever is on the side of the foot near the button holder.) Place a corner of the fabric under the foot and press the up/down needle button twice. Pull the thread to the back of the fabric. Then position the fabric at the starting point where the button hole is to be sewn. Make sure that there is no gap between the slider and the stopper on the foot. Select the button hole style (06 regular, 07 oval, 08 keyhole). Then set the machine to sew. This is shown in the manual on pages 53-63 (pages 59-70 in the PDF).
For a rolled hem on a lightweight fabric, use stitch 10 and set the stitch width to 3.5 and the stitch length to 0.8. Use the Satin Stitch pressure foot (labeled F). Lay the edge of the fabric in the center of the foot. (Make sure that there is a clean cut to the edge with no dangling threads.) See page 48 of the manual (page 54 of the PDF).
Elna has the manual for the Experience 540 here on their manuals page: http://www.elnausa.com/en-us/pages.php?page=107 . The Experience 540 is listed on the left in the section labeled Top-loading 7 mm Max Stitch Width Machines. The direct link to the manual is http://www.elnausa.com/data/files/2_users/55/Inst-book-EL540%28EFG%29.pdf .
I hope this helps.
May 13, 2017 | Elna Sewing Machines
How do i create a rolled hem using my Platinum 750?? Do i need a special presser foot?
by rolled hem I imagine that you are trying to put something like rope in the hem to make a round edge
You can buy a 1/2 foot that allows the needle to get close to what ever is making the roll
see your local sewing machine shop
Jul 07, 2016 | Platinum Sewing Machines
How to sew narrow seams
A hem gauge foot is adjustable and can aid with small seams
Jan 03, 2016 | Sewing Machines
Hi, I have purchased an adjustable blind hem foot for my Classica 90. Would you please advise what the setting for blind hemming is on the sewing machine is? I cannot locate it. Thank you.
Perhaps this video will help:
How To Sew Blind Hem Stitch 2
Unfortunately, after reviewing your machine's manual, your manual does not indicate that your machine provides a blindhem stitch. The blindhem stitch generally is a stitch that takes several straight stitches and then zags to the left to catch the garment fabric. You can, however, use a zig-zag. You will just have more stitches into the garment that may show on the right side.
Aug 23, 2015 | Husqvarna Sewing Machines
How do you do a blind stitch on a Viking Fresia 415? What foot do I use?
You need a foot like this one so you can guide the folded edge of the fabric hem along against the white plastic foot. This is a generic style snap on blind hem foot, your machine should have one in the accessories that looks like this if your machine has a blind hem stitch included in its functions.
You fold the fabric into a upside down Z shape and run the top folded edge along the white guide with the fabric under the foot, hard to explain but once youve done it once, it makes sense.
You need to select the stitch on your machine that looks like 3 small zigzags, then one bigger one, or 3 straight stitches, then one zig zag to the side. This is the blind hemming stitch. You'll possibly also have a blind hemming foot to use, which helps with guiding the fabric fold into the machine and keeping it even. But if not, you should be able to buy one from your Huskqvarna dealer or a generic one from www.sewingpartsonline.com may well fit.
You'd be best served by visiting http://sewing.about.com/od/techniques/ss/machineblindsti.htm for photos and intructions if you've never done blind hem stitching before.
Blind hemming works best when hemming straight edges of fabric such as a ruffle on a full skirt - if there is any curve in the seam, it gets much harder and the result won't look so good. In essence, you press the fabric hem up, then fold the hem edge back under so you have a "S' shape, then sew along the single layer with the folded edge sitting against the foot guide. Then when the machine takes the 4th wide stitch, the needle swings to the left and catches a small stitch into the upper folded layer, then back onto the hem. The trick is adjusting the stitch so that the wide stitch doesn't show much on the right side of the garment
Sep 06, 2011 | Sewing Machines
I need to hem a t-shirt but not sure how...ie: type of stitch,length,needle et...do I need to zig zag first then finish off with a stretch stitch ? Thanks
The best way to hem around a garment where the seam is going to receive stretching during wearing is with a stretch twin (double) needle.
Pretty easy, just turn up an even hem of 15mm right around the hem line (I am assuming that the bottom edge is even, if not, trim it up first), and press this hem allowance up, pin if you have a jersey that won't stay flat but many cotton knits are fine and the pressing will be enough.
Then thread up your sewing machine for twin needle sewing, refer to your manual if you have never done this before. You will thread two spools of same colour thread up on top of the machine and bring both threads through all threading points down to your needle, then one through each needle eye. Some machines will have a tension device where you can run each thread on either side of a tension disc, most will have twin spools on top of the machine to hold both spools.
You need a stretch twin needle, Schmetz do these in two sizes,
Stretch Twin
Size:
2.5/75, 4.0/75
Twin needles look like this.
tally_girl_65.jpg I prefer the 2.5mm gap between the needles. Dont try with a regular twin, it must be stretch needle with ball point points. On some computerised machines, you need a twin needle with a blue bridge, on mechanical machines it will have a red bridge (something to do with horizonal hooks I think). But read your manual or look in your accessory box, your machine may have come with a twin needle and if so, make a note of the needle bridgecolour, then buy that one next time.
Now, set the machine for a straight stitch and place the garment right side up, with the folded hem allowance underneath on the sewing machine and align the folded edge on your 10mm marking. Start at a side seam, and stitch SLOWLY around the whole hem line until you get back to the starting point. Stop, cut your threads and press again. Voila done. I never bother to zigzag a knit fabric, just stitch it. Knits don't fray.
Aug 20, 2011 | Sewing Machines
Which food sood i use to make an invisible hem
blind hem foot is good if you want to machine stitch a hem but not have a seam showing. it will have an adjustable piece you can move left or right with a screw. but blind hemming works best on straight grain and not on a curve like a skirt hem unless its a knit fabric that gives. to make a blind hem press the hem allowance up then turn the main garment piece back to form a Z shape. you then stitch along the hem side with your blind hem foot guidr running along the top fold and use the blind hem stitch which looks like three little zigzags then one big zig far to the left onto your folded piece taking a little 'bite' - this stitch shows on the right side when you press the top of the Z back flat. so you need to adjust the foot position and how wide the needle swings to minimise this stitch showing. hope this makes sense and helps you with your sewing.
Dec 19, 2010 | Elna 2007 Mechanical Sewing Machine
Skipping stitches on coverstitch machine
To avoid skipped stitches on a coverstitch machine you need to use ELs (extra long) or SUK (stretch) needles and good quality thread. Poor quality thread is too fluffy and varies in thickness which can cause stitch problems. Try Maxilock thread from a cone or use maxilock on looper and regular sewing machine thread through needles and see if this improves the stitches. Also loosen off the lower looper tension to zero and see if this helps. If you are hemming around a garment and sewing across an overlocked seam then you need to minimise bulk too. lightly press the seams into the diretion you want them to sit when garment is finished, press the hem up, then force the seam allowance in the hem turnup area to the opposite direction. This spreads the seam bulk in both directions.
There is a knack to coverstitch machines but a good cover finish is quicker than twin needle on SM.
Apr 04, 2009 | Janome 900CP
Elna 2007
If you want to do blind hemming you need to find the stitch on your machine that looks like 3 small zigzags, then one bigger one, or 3 straight stitches, then one zig zag to the side. This is the blind hemming stitch. You'll possibly also have a blind hemming foot to use, which helps with guiding the fabric fold into the machine and keeping it even.
As the previous poster said, blind hemming is a little difficult to explain. You'd be best served by visiting http://sewing.about.com/od/techniques/ss/machineblindsti.htm for photos and intructions, getting a copy of a manual for your machine (if it doesn't have this stitch, then you're going to need to find another way) or getting a ibrary book out.
Blind hemming works best when hemming straight edges of fabric such as a ruffle on a full skirt - if there is any curve in the seam, it gets much harder and the result won't look so good. In essence, you press the fabric hem up, then fold the hem edge back under so you have a "S' shape, then sew along the single layer with the folded edge sitting against the foot guide. Then when the machine takes the 4th wide stitch, the needle swings to the left and catches a small stitch into the upper folded layer, then back onto the hem. The trick is adjusting the stitch so that the wide stitch doesn't show much on the right side of the garment.
Sep 07, 2008 | Elna 2007 Mechanical Sewing Machine
As Seen On TV Easy Stitch Mechanical Sewing Machine Logo
405 people viewed this question
Top As Seen On TV Sewing Machines Experts
Tally Girl
Tally Girl
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
