Question about Husqvarna Interlude 445 Sewing Machine
I need to sew with kevlar thread on medium weight fabric that is nylon coated with vinyl and I can not get my machine tension set correctly can you help.
  • Cathy Amspacker Rogers
    Cathy Amspacker Rogers Jun 06, 2010
    I have tried all different settings with upper and lower tension. My question is is the heavy kevlar thread too thick for my machine and is that what is causing the tension problems.The fabric is nylon coated with vinyl.
  • 713 Answers
Hi,here is a detailed solution to help you solve the problem you are encountering with your sewing:
If you are using an old machine,the feed dogs could be worn,but if the feed dogs are not worn,here is another tip to help you,
check that the upper thread is not stuck or caught on something,preventing the thread from unwinding off the pool.
Now,check that you have properly fed the upper thread through all the guides,after a visual check with the presser foot down,pull gently on the free end of the top thread to see if its running smooth and clear,perform the same test on the bobbin thread,if either of them feel like it's caught or not unwind smoothly, check your instruction manual to ensure you are threading the bobbin and the machine correctly.
Next,remove the top thread,bobbin and the needle,with no thread or needle,try sewing the fabric,observe if the machine will feed the fabric under the presser foot,if it does you may need to increase the spring tension of the presser foot a bit.
Thanks and good luck
Posted on Jun 06, 2010
    President:
  • 1,469 Answers
Hi,the solution is possible, The answer is a little bit long, so i will give you a link to get the manual on how to adjust the sewing machine.
ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf.
Take care.
What should the upper thread tension be set at on a Bernini 750
There is usually a mark on the tension dial that indicates the default setting--generally, it is at the midway point between high & low numbers. However, the correct tension is dependent on the fabric, thread, and needle you are using. Some stitches require a different tension setting, ie free motion quilting, as well as lighter weight vs heavier weight fabrics will require some adjustments.
Understanding Thread Tension Threads
How to Adjust Sewing Machine Tension on Craftsy
Ideally, for straight stitching on medium weight fabric, the midway point should be close. However, the tension is correct when the top and bobbin threads meet in the middle of the fabric.
The video tutorials here may be helpful:
https://www.youtube.com/watch?v=0900v0dSmt8
Feb 08, 2017 | Bernina Sewing Machines
How do I adjust the tension for straight sewing?
First, be sure you are using a brand-new needle and that the needle, thread, and fabric are compatible.
All About Needles
When you thread the upper thread, be sure the presser foot is ALWAYS RAISED so the thread will seat properly in the tension disk. Also, confirm that the machine thread pathway is correct.
Remember that when fabric types/weights are changed, the needle/thread should be changed accordingly. (Needles should be changed often to attain the best sewing experience and minimize unnecessary frustration.) The tension may also need to adjusted. Tension is not static. It should be adjusted to fit the project being sewn. Unless one continuously sews with the same fabric, thread, and needle type would the tension adjustment remain at the same setting, but machines do change over time so a tension setting that worked last year may not look the same this year.
The factory standard tension setting is the midway point between the high & low numbers. However, please understand that machines vary and that sometimes this standard setting may change with time and use. The midway point should only be the beginning point and is most likely suitable for medium-weight fabric. Also, usually the bobbin tension does not require frequent adjustments unless a particularly heavy- or light-weight thread is used in the bobbin--sometimes the bobbin tension will get out of whack requiring adjustment (consult the owner's manual or search the internet for instructions for adjusting bobbin tension). In the majority of cases, the tension adjustment is made to the top thread.
Test your straight stitch on your fabric (may be helpful to use a different color thread in the bobbin so it is easier to see any tension issues). If the bobbin thread is popping up to the top of the fabric, loosen the upper thread tension. If the upper thread is looping or showing on the bottom of the fabric, tighten the upper tension. Keep adjusting until the upper and bobbin threads meet in the middle of the fabric.
FWIW, the same process would be used for zig-zag stitching. Just make sure that the tension is not too tight or it will cause the fabric to pucker (or tunnel).
Mar 07, 2016 | Sewing Machines
What are the correct top & bottom tensions for this machine?
Both tensions are preset at the factory. Normally, the bobbin tension is the last one to adjust. Most often tension adjustments are made to the top thread. The factory standard setting for the upper thread is the midway point between the high & low numbers, however, each machine is different and may need slight readjustment.
The tensions are correct when both, the upper and bobbin, threads meet in the middle of the fabric. Tension is not static. Differing fabric weights, thread, or needle sizes may necessitate a change to tension. Lighter weight fabrics like chiffon will require a different tension setting than heavy fabrics like denim. Always test first on scraps of the fabric you plan to sew. Get the tension set the way you want it before you begin sewing your project.
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Adjusting Sewing Machine Tension to Prevent Problems
How to Adjust Tension Sewing Machine
Mar 04, 2016 | Sewing Machines
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Make It Handmade Threading Your Serger or Overlocker
Dec 19, 2015 | Sewing Machines
Cant get bobbin tension right
Tension of the bobbin depends on the type of fabric you are sewing on. Thin fabrics usually require mid to higher settings. Heavy weight fabrics require lower or looser tension. To check the tension, set to medium number, take a few stitches, then check the underside of the fabric. If the threads are too loose, be sure needle is raised, and change the tension to a higher setting. Take a few stitches and check again. If the fabric pulls too tight, then loosen the tension. Top threads and bottom threads should be the same when you have the correct tension. Your manual may have suggested settings for fabrics also.
Jul 04, 2014 | Husqvarna Freesia 415
Borrow sewing machine from sister unsure how to thread it correctly and when i do the thread fromthe needle keeps breaking when i try to sew its a brother XL-5130 sewing machine and i know nothing on how...
you need to go to this webpage http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/doc/manual_index.html?reg=us&c=us_ot&lang=en&prod=hf_xl5130eus&dlid=&flang=English&type2=-1 and download the instruction manual for this model. It has the threading up instructions plus selecting stitches, winding a bobbin etc.
The thread breaking is most likely due to incorrect threading up of the top thread. I suggest that if you can, you print out the manual, put into a little folder and place beside the machine and refer to it often. Follow the instructions in it on winding a bobbin, putting it into the bobbin case correctly and threading up the top thread. Make sure the bobbin goes into the case the correct way, as per image.
Remember, ALWAYS THREAD UP TOP THREAD WITH THE PRESSURE FOOT RAISED, this keeps the tension discs open so the thread can seat into the tension device correctly. And you must get the bobbin thread into the tension spring fully and then place the bobbin case into the shuttle using the little latch so it stays in place.
Also, new needle for every new project, and put the needle in "flat shank to the back". It will take standard domestic sewing machine needles 705/130H but it is important to select the correct sized needle for the fabric you are sewing so that the needle can penetrate the fabric but not leave big holes. So for light weights like chiffon you want a size 60 or 70. For medium weights a size 80 and for heavy fabric like denim or a coat weight wool you would use size 100. Ball points for stretch fabrics so that the needle pushes between the fibres and a regular point for woven fabrics.
I trust this helps you out, 4 thumbs up if so. Thank you.
Jun 28, 2011 | Brother XL-5130 Mechanical Sewing Machine
My bobbin stitch is loose. I have tried adjusting tension and have changed the needle.
A. To correct loose stitches, try the following: (1) Balance the thread tension. If the stitches are loose on top of the fabric, decrease the tension to the next lower number. If they are loose on the underside set the tension to the next higher number. (2) Make sure the needle/upper thread follows the threading path. (3) Check to see that the bobbin case is threaded properly. (4) Use a different size needle. For fine fabrics, use a smaller needle (size 9, 11); medium-weight fabrics require a size 14 or 16. And use a size 18 or "Denim" needle for heavy corduroy or denim.
Sep 20, 2010 | Singer Curvy 8770 Electronic Sewing...
Machine jamming
Hi! It's possible that the thread is too heavy, but there are other possibilities also. What size needle are you using? Is it a leather/vinyl needle? Also, it could be a tension problem, so try adjusting that on a scrap of the vinyl.
I found this bit about marine threads (http://www.seattlefabrics.com/thread.html). There are different sizes/weights of marine threads and it could be that you need to find a different marine thread.
Hope this helps!
Robbie
Apr 28, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
The material gathers when i sew
Rethread the machine from the spool to the needle.All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.
You need to be sure your tension is working correctly. Adjust the tension to 9 and pull the thread. It should be hard to pull. adjust the tension to 2 and it should pull much easier. If it works as described, then adjust the tension to 4 and your stitch length to 2.5 and try it on some medium weight fabric.
If you are sewing on light weight fabric set your stitch length to 1.5 or 2. You may even have to reduce the tension to less than 4. You can reduce the tension until you see loops on the bottom of the fabric at which point you should tighten the tension to remove the loops.
sewman7
Jun 28, 2008 | Elna 2007 Mechanical Sewing Machine
Husqvarna Interlude 445 Sewing Machine Logo
54 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
