Question about Polaris 800 Twin Sportsman Ride on Toy
How do I drain the gas in my polaris 800 razer
    Genius:
  • Polaris Master
  • 1,508 Answers
Wrong forum
Posted on May 23, 2012
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
How can I get better performance and gas mileage with my 2015 polaris switchback 600 pro S?
2015 Polaris 800 Switchback Pro-S Review + Video
www.snowmobile.com > Reviews > Polaris
Sep 11, 2014 - 2015 Polaris 800 Switchback Pro S Review Video: Polaris 2015 800Switchback Pro S is the right choice for the vast majority of us If you can get one itwill ... or Pro-X - the new AXYS chassis Pro-S is by far the more versatile and, ...year 2015, Polaris totally re-imagined on- and off-trail performance and ...
2015 Polaris 800 Rush Pro-S Review + Video
Apr 15, 2014 - 2015 Polaris 800 Rush Pro S Review Video: The 2015 Polaris RushPro S is a ... the high end Pro-R version with a choice of a 600 or 800 engine. ... "X" Games, looked at the big picture of snowmobile performance. ... Interestingly, the Rush Pro-S tends to be much more versatile than its Pro-X counterpart.
2015 Snowmobiles of the Year: Best of the Flatlanders
Dec 21, 2015 | 2015 Polaris Switchback 600 PRO-S
2006 sportsman 800 twin wont fire at plugs gas burner
If you have no spark , check kill switches for corrosion, does the light work when u turn it over ?
Nov 09, 2015 | Polaris 2006 Sportsman 800 Twin EFI
Trailblazer 250 wont start
check/change, Battery, spark plug, remove air filter, use starter fluid, drain all old gas. use premium new gas. usecarb cleaner...should run,.
Mar 28, 2014 | Polaris ATV
Where is the gas drain plug on my polaris 500 ho atv/ need to drain bad gas from the tank
There is no "drain" so to speak.. you need to remove the tank, then remove the petcock,,,the gas will then drain out..
Feb 17, 2012 | Polaris ATV
How do i drain the gas tank?
at the petro turn off there is a gas line take it off an it will drain out.direct the gas to a jug with a hose or funel.
Mar 23, 2011 | Polaris ATV
I have a 1995 Polaris Magnum 425 4x4 4-stroke has gas in the oil after starting it. It was sitting since January. The oil tank and crankcase were filled with gas. It also comes out the pull starter hole.
This is likely a carb problem. It's a common problem on Magnum engines. Check the main jet and the diaphram on top of the carb. Always turn the gas off on these when you're done riding. This way, if the carb is allowing fuel to drain in the oli tank, it won't drain the whole gas tank (which is what happened to you). This is not a piston ring problem with that much gas in the oil. good luck
Jun 28, 2010 | Polaris ATV
2008 polaris sportsman 800 efi 4x4x2
clean or replace your air filter and check and clean your throttlebody
Apr 03, 2009 | Interactive Toy Concepts Polaris Sportsman...
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
Polaris 800 Twin Sportsman Ride on Toy Logo
53 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
