Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
How to stop leaking fro bottom of machine - Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
  • 410 Answers
I've fixed these before and it's not easy. Your leak is a tear on the flexible hose that goes from the suction take-up body to the upright handle. Tape will temp. fix it, but you have to cut off the bad piece and re-attach it if you want a permanent repair.
Posted on Jun 06, 2010
Why has my cleaner stopped working.
You did the right thing; you could get shocked when wet.
Jul 03, 2015 | Vacuums
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i get my bissell to stop leaking water?
The rubber gasket on the bottom of the 2-in-1 tank is probably lodged in the base of the unit. It should be connected to the nozzle on the bottom of the 2-in-1 tank. You can pull it out of the base and reattach it to the tank. This should stop it from leaking. The formula tank on the back has the same gasket so you can pull that out and see how it should fit on. Hope that helps.
Apr 05, 2012 | Bissell 2X Proheat 9200 rug cleaner
I have a dirt devil upright vision and when I am sweeping it will shut off like it had overheated or something. I will unplug it and let it sit for a few minutes and it will start back up and then after a...
Hi Cassidy. You are probably right about the motor overheating. The usual cause for overheating is a clog some where on the bottom of the machine. Check for anything that could be blocking the dirt fro going into the bag. Hope this helps Chris
Feb 20, 2011 | Dirt Devil Vacuums
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Hi, the Hoover f5915-900 that we have is leaking the clean solution when we are using the attachment. but the leakage seems to be coming from the bottom of machine
With this style of machine there are hoses, or connections to transfer the cleaning solution. these can fail after some time. Stop using the machine, leaking fluid onto the internal parts can become a electricution/fire hazard. take the unit to a service center for repair.
Jan 01, 2010 | Hoover F5906-900 Upright Steam Vacuum
My Hoover Carpet Cleaner is leaking out the bottom when I use the hand tool
this could be the little white valve that the water comes out of, if its leaking from here or if its leaking at the bottom of the machine it could be the pump
Jul 19, 2009 | Hoover F5906-900 Upright Steam Vacuum
Carpet Magic Steam Machine Hr 3-2 Leaks
carpet magic steam cleaner pump problems.
Apr 24, 2009 | Vacuums
Hover steam vacume F5864
Is it running out of the bottom of the tank, or at the bottom of the machine. If at the bottom, you have a water line off. If at the bottom of the tank, there is a water seal that the tank sits on, may have to replace that.
Oct 03, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
116 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
