Question about Revo America 8 Channel Complete Digital Video Recording System, R8DSYSTEM
Spots on the lenses. Have cleaned them with lens cleaner and that didn't work, tried washing the lens cover lenses with soap and water and then with alcohol. That didn't work either. I have had a lot of cameras but none with this problem. Can you give me an idea to get rid of these obstructive spots. Thank You Judi
  • sjshaw518 Jun 08, 2010
    Thought I would let you know that I used my film on one camera and it worked, only problem is I only had a light tint film and it should be a clear film. I have to put the film on with a drop of alcohol or water. I think when they put their film on they used some sort of oil and it will not clean off. I don't want to use a harsh cleaner that would lift oil. Will continue checking out this problem. We got four outside cameras with the system and ordered two more. The two we ordered are fine. No oily smears at all. Will try again to reach the manufacturer to see if they had this problem with other cameras they sold in a system and if so what they did about it. Judi
  • 4,889 Answers
There is a special kind of liquid available to clean the lenses. I have personally used it to clean a variety of camera lenses so it might do the trick for you too. Note that you should never clean any lens with soap. You can get the cleaning kit from the link below
http://www.amazon.com/Nikon-Complete-Lens-Cleaner-Kit/dp/B000EF3YQI
Posted on Jun 06, 2010
  • 7 more comments
  • sjshaw518 Jun 06, 2010
    Is the nikon kit a lot different than the on I have from Canon?
  • eagle338
    eagle338 Jun 06, 2010
    Not really. Sorry I didn't read the part where u said u have used the lens cleaner. Anyways what do the spots look like? It might be that the spots are on the insides of the lenses. Can I have an image of it so that I can suggest an appropriate cleaning procedure?
    I can't send image because I have not connected the system to my computer yet. I am using a monitor right now and the spots are a sort of hazy spots and wisps like you wiped a smudge and it didn't all come off.
  • eagle338
    From your description it sounds like moisture has got inside the lens. Not an unlikely problem especially if you use your cam in areas with high humidity(such as beaches). The lens system has to be disassembled and cleaned from the inside. I would suggest that you get it done by a qualified proffessional to avoid damaging it. Most Camera lens opticians should do the job for you.
    I don't believe it is moisture and it moves around when we clean the lenses. We are out on the desert and it is 110* today with little or no humidity so if it was moisture it would dissipate. It is only see on the lenses after dark , we can't see it on there during the daytime. The lenses came with a protective film of plastic on them which we removed . Maybe there was something on the film. Oil or something to make the film stay in place.
  • eagle338
    Does cleaning affect the blotches atleast slightly? If not then its confirmed that whatever it is , its one the inside. May be moisture but something must have gotten into it. Happens time to time.
    Yes cleaning does make a difference. It moves the spots or the wisps sometimes almost all gone. It gives us just enough courage to clean them again and again and again. I am going to try putting the plastic film back on one of the lenses to see if it was something that was to stay there. I have some film that we use on our game camera to stop flashback. I will try that and let you know how it goes tonight,
  • eagle338
    eagle338 Jun 07, 2010
    Sure thing let me know how it goes. If it is working partially then a better cleaner might do the job. Nikon has always worked for me and it might work for you too..
  • eagle338
    eagle338 Jun 09, 2010
    Glad to hear that. Hope you will be able to remove that completely.
    Sai.
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
I have a Mintek 10.2" portable dvd player (MDP-1070) and it has trouble loading dvds. It will either sit there and continue saying loading or else it will say "no disc" and I know it was...
I would suggest to try using a lens cleaner and see if that restores the functionality. If the lens cleaner did not work, the lens could be becoming defective and it should be replace.
Jul 02, 2008 | Mintek Televison & Video
Cleaning and lubrication
Cleaning a lens should only be done with a non-scratching cloth and tissues designed for optics; moistened with plain water or cleaning solution designed for optics. Use of paper towels, glass cleaners, ammonia, etc. can scratch and strip special optical coatings from lenses. Apply water or solution to cloth or tissue - not to optics.
Do not lubricate lenses. Lubes attract dirt and dust and can seep into the lens and gum up aperture blades and eventually cause them to stick. Nearly all lenses do NOT require lubrication. Lenses should be cleaned professionally when not working correctly.
Jan 11, 2012 | Cameras
How to repair scratched polarized lens
Unfortunately there is no remedy for this kind of damage, the lenses have to be replaced. For the future some helpful tips: polarized lenses are delicate, so never!!!! put your glasses somewhere with the lenses touching for example the table or any other surface always transport them in their case never clean them with ready made wet wipes ( with the time this will ruin the cover ) if they are really dirty clean them with warm water and a mild soap and dry them with a very soft cloth use a little microfiber eyeglass cleaning cloth you can get at any optician, often for free following these instructions you will enjoy perfect glasses for a long time
May 14, 2011 | Angel Serenity Sunglasses
Bought a used one need to wash the cover
Hi there, I would hand wash it. Sunlight soap is the best and give it a good soak and rub with your hands and the marks should come out. DON'T put it in the washing machine, so many websites say just machine wash but I don't recommend it. I saw someone trying to sell a second hand hood once and it had completely skewed out of shape. They don't take long to wash/ rinse until water clean and squeeze hard and dry in the shade. Don't put any cleaning substances/ upholstery cleaners on it, Sunlight soap is the all time favourite for this sort of thing and gets most marks out. If you don't know what Sunlight soap is then any pure soap or baby friendly detergent/ washing soap would do (any with a picture of a baby on it.
Jan 25, 2011 | Kolcraft Lil' Limo 46880 Twin Seat...
Dust spots on images
this will give you the idea how to clean the lens and have lens cover which is available in market to protect it from dust
http://www.picturecorrect.com/photographytips/207/cleaning_camera_lens.htm
thank you
Sep 22, 2009 | Leica M8 Digital Camera
Not cleaning properly
Our Whirlpool Quiet Wash plus is 20+ years old and was on its way out the door because of erratic white residue, spotting, and film.  Nothing worked: vinegar, different soaps, more soap, less soap. Today I opened it up and started digging behind covers and checking the insides - multiple places were clogged with a soap/mineral film - ugly! I sprayed the insides with Restore 4 (a tile cleaner) and scraped and brushed and broke loose the hidden deposits. The only thing I didn't open was the sump pump - but now know how to do so. (thanks FixYa) Then I added about a 1/2 quart of vinegar and ran it full hot on the heavy wash cycle, added more vinegar between each cycle and let it dry.  It looks super inside - the gunk is gone.  I am now washing a load of glasses and am hoping for the best!
Feb 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dropped sigma 70-300mm lense in water, can I get rid of water spo
Hi The front lens will screw off after you remove the front cover ring and you can clean it
Feb 26, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Spot on digital camera lens
No. You can't take the lense apart for the cleaning by yourself. Any expert pro camera repairer will do the job
Aug 08, 2006 | Kodak EasyShare DX6340 Zoom Digital Camera
Revo America 8 Channel Complete Digital Video Recording System, R8DSYSTEM Logo
43 people viewed this question
Top Revo Home Security Experts
Lawrence Oravetz
Are you a Revo Home Security Expert? Answer questions, earn points and help others
