Atwood 8900-111 furnace lights then goes out before up to temp. It cycles a couple more times like this then doesn`t light at all. I shut unit off for a few minutes then try again and get the same results.
hotuna
  • 288 Answers
SOURCE: cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Posted on Dec 25, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: room temp is not where it should be before furnace shuts down
Did the installer check the amperage at your thermostat and then adjust the heat anticipator? Or you may need to have the blower time settings changed to suite your needs. Get them back in to check.
Posted on Nov 11, 2008
gear001
  • 59 Answers
SOURCE: i have a rheeme 90+ effeciency furnace that will
You Have problem with the flame sensor. You can clean it with sand paper, but most likely it need to be replaced. Your looking around $250 with parts and labor from a Air Conditioning Company
Posted on Oct 14, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Furnace tries to light but misfires
Check the air filter.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Feb 27, 2010
Testimonial: "This was a very helpful website and very respectful response. I will revisit this site if necessary. Thank you very much."
Therinnaiguy
  • 1420 Answers
SOURCE: Furnace cuts off before reaching set temp.
You can make sure it is not the thermostat by crossing or jumping the R and W terminals (or associated wires) together. This will keep the furnace calling for heat. As it is approaching set temperature, get in front of the furnace and inspect the air filter to make sure it is clean, watch the control module for any error codes that may be turning off the system prematurely.
Posted on Mar 07, 2010
Atwood rv furnace My rv atwood furnace won't light.It just blows cold air.
check gas if ok see if unit fan on auto if ok see if ignitor has voltage when starting
Dec 27, 2017 | Water Heaters
Atwood 38591 Excalibur xt 1522 LP two stage furnace. Operates on high fan only
Hi Dave. I'm Roger. Its normal for a furnace to shut down completely when the set point on the thermostat is reached. The first and second stages are used when the temp. gets close to set point. The heat output drops to its low stage at around 3 degrees before set point. Check your owners manual for specifics on the fan though.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
Atwood motorhome furnace won't stay lit
I would say this is your electronic ignition system but it sounds like it is not getting gas. This is why they do a 3 time try and shut off. Check you supply line right down to the regulator. Hose could have got partially kinked along the line as well.
Jan 31, 2013 | Heating & Cooling
Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Feb 11, 2012 | Ruud Heating & Cooling
I recently had a ducted gas heating unit undergo a routine service. At the same time, the technician identified an external gas leak. The gas leak was subsequently fixed by another technician who noted...
The tech that fixed the gas leak had to shut the main gas supply off so if he didn't bled the line to the furnace you may still have air in the line....... Go ahead and shut the furnace off and retry to start it again it takes a couple of trys to bled the air out through the pilot.... And if that doesn't work I would call the first tech and have him recheck it......that is assuming that you have an electronic ignition type furnace.
Apr 19, 2011 | Heating & Cooling
Furnace has begun to fail to cycle on when shuts off but if switches on base of furnace are switched off and back on will cycle on until desired temp. is reached but will not come back on unless switches...
This sounds like it may be a control board issue. If the thermostat has been changed, and the unit operates correctly after it has been reset, then I am thinking the circuit board in the unit is faulty. When the unit stops working, check for a blinking or steady red light on the circuit board. Alot of the time this will be on or blinking and there will be a legend that tells you what each light stands for. This can help you troubleshoot the issue.
Mar 01, 2011 | Intertherm Heating & Cooling
Red light blinks 4 times, will only cycle once
the high limit is sensing the internal temprature of the furnace.If your filter is very dirty or you have to many of the registers/dampers shut it will cause the temp. of the furnace to exceed its rating and the high limit will open the circuit and shut down the flow of gas. Your blower will then run until the furnace has cooled and the switch will close and allow it to come back on. This is bad for your furnace, make sure your filter is clean and you dont have to many registers shut. If you have run the unit without a filter the problem could be much more sever requiring blower wheel and coil cleaning and possibly a cracked heat exchanger.
Sep 12, 2009 | Goodman GMS90703BXA Heater
Pilot light goes out after water heater shuts off.
sounds like the wiring is backwards check the wiring
also check the thermo coupler
Jul 27, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
