Question about Brother MFC-9840CDW Laser Printer
Drum error --how do i fix it? - Brother MFC-9840CDW Laser Printer
    President:
  • 1,194 Answers
Look on the right side of each drum unit, there's a gear on each and each has a number that needs to align on the top with the marks make sure all drum gears are in synch.
Also clean the drum because this error is also caused by dust.
Good luck and have a nice day.
Posted on Jun 06, 2010
  • kwalton425 Jun 06, 2010
    sorry do not see a number. is the gear on the printer cartridge on the right as i open (and face) the printer?
  • Ranglo
    Ranglo Jun 06, 2010
    Visit this link to know about the position of the drum unit.
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
How do I fix a fault code error 004-363 on my Xerox WorkCentre 24?
That error signifies a black drum motor failure. Try remove black drum and swap with another color and see if error follows the drum. If not it's either a bad drum motor or mcu board.
Jun 26, 2015 | Xerox Office Equipment & Supplies
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
Sharp FO-4470: Error message is: "check cover or drum"
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
Apr 23, 2010 | Sharp AR-F152 Fax
System Error E810 - how do I fix?
E810 and/or "CHECK TONER/DRUM CRG" message on control panel.
Something is amiss in the drum unit. Make sure that the drum unit and developer units are attatched together at the front and rear. Use cation when removing, as the drum is light and scratch sensitive.
If all is well there, either call a service tech or replace the drum unit(expensive) approx. $135 for GPR 10 Drum unit.
Jun 02, 2009 | Canon imageRUNNER 1370F All-In-One Laser...
Error Code E00002-01c0
you probably mean E000020-01c0 bad yellow drum codes in order 01Y 02C 03M 04B
Apr 10, 2009 | Canon imageRUNNER C3200 Copier
E 04 error
E04 indicates a drum motor communication problem with the micro. It most often requires solder connection rework on one of the boards where the fpc cable from the drum is terminated. This is a fix for a pro. Good luck, magic seadog
Jun 13, 2007 | JVC GR-DVL310 Mini DV Digital Camcorder
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Brother MFC-9840CDW Laser Printer Logo
202 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
