Question about Dell Computers & Internet
KEEPS GOIN OFF AFTER THE FAN MAKE NOISES, SHUTTS OFF VERY OFTEN AND GETS VERY HOT
    Scholar:
  • 97 Answers
Need the make & model & O.S. to help you. You can install this software any way to control the fan. Set the fan to always on and see if it cools down. If the fan is noisy it should be replaced and clean inside of laptop. Dust will clog fan and overheat laptop. Over heat causing the shut down condition. This is a great toll to keep Dell laptop's cool. Let me know if it works.
http://www.diefer.de/i8kfan/faq.html
Posted on Jun 07, 2010
How do I my whirlpool model G115NDXZB0
You may have a compressor failure, due to the failure of the fan.
Have you tried turning the fridge off for a few hours and re-starting it?
If the compressor then starts without any unusual noises, it might just be overheated, and a replacemaent fan will cure it.
Otherwise, it looks like a new compressor and fan will be needed.
May 22, 2016 | Whirlpool Refrigerators
My acer aspire ax 1300 is shutting off at startup and it gets hot plus the fan is running really slow making noises and it keeps showing windows error recovery it keeps shutting down? please help? it...
Your CPU is overheating. When this happens the safety mechanism causes your computer to shutdown to prevent further problems. The CPU fan will need to be replaced.
Apr 09, 2014 | Acer Computers & Internet
I have 2000 3.1 mailbu
1st: check if the radiator gets hot too: if not it is the thermostat sticking closed.
If the radiator gets hot too, the fan should come one: if not, the thermoswitch or the fan or the tempp sensor is broken
If the fan comes on and it still overheats, the radiator is plugged up, this is chaeckable with an infra red thermometer...
Jan 08, 2012 | Chevrolet Chevy Cars & Trucks
Dryer gets too hot and shutts off till it cools down
CHECK YOUR VENT HOSE FOR OBSTRUCTION OR CRIMPAGE! RATE ME IF I AM CORRECT!
Aug 25, 2010 | Dryers
The fan keeps stopping & heat element gets red hot
hi,
the fan bearings may be clogged up with grease and fats from cooking causing the fan to start and stop or the bearings are worn causing a restriction. if you continue to use the fan force on the oven the ring element will get too hot and you will need to replace this as well. i suggest you replace the fan as soon as possible.
Aug 11, 2010 | Ovens
Sony pcg-k33 fan is making noises i took comp apart and cleaned fans with brush but noises still exists and are loud and squeeky
that's the actual fan, brushes may need some fresh oil (like wd40), means opening the lappy back up and removing the fan and dropping some oil inside the fan bearing area (where the fan and hub connect)
this should stop the sounds and help the fan move freely.
though this is also a sign that the fan is unhealthy and will eventually need replaced.
hope this helps.
Jan 03, 2010 | Sony VAIO PCG-K33 Notebook
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Dell lcd inverter gets hot
check to see if cooling fan is working
Jul 09, 2009 | Electronics - Others
Cinego Automatically shutts off after 15 seconds
had the same problem - replaced the lamp even though it only had 632 hours on it. seemed to fix the problem - 10 hours and 4 moves later still doing ok
Jun 12, 2007 | Radio Shack Cinego D-1000 Multimedia...
Computers & Internet Logo
78 people viewed this question
Alun Cox
