Question about Samsung SGH-D900 Cellular Phone
Message alert tone
This may sound easy but yet it's driving me nuts. How do I set a message tone for incoming SMSs there does not seem to be an option like this. I would like to set my own SMS alert?
    Brigadier General:
  • 7,752 Answers
Sorry but they do not have that option, i know it sucks but thats samsung
Posted on Jun 10, 2008
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
How can i change my message tone on my samsung f480 from the standard tones set on the phone
Instead of changing the ringtone settings, tap the message alert tab (in the top centre of the display).
A set of message alert settings appears . You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
To change the Message alert tone, press the Message alert tone panel .
In the menu that appears, press Change.
Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds) .
In this example, press Use my alert tone.
Press the Sounds option. In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files, Ringtones that are loaded onto the phone, or My voice clips .
In our example, we'll again choose a file from our Music folder.
Press the Music option. A list of suitable MP3 tracks appears.
Tap the one you want in order to highlight it.
Press Options, then tap on the Select menu option to install it as your message alert .
You are now taken back to the Normal profile settings, where the Message alert tone has changed .
To save this change, press Options and then Save .
Alternatively, press Back and you will be asked whether you want to Save? Press Yes
Jan 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Can not change message tone.
try to go to music files then select a tone you want to be your message alert tone then used option keys and find the command for "use as" or "set as",.
or else if your phone have a profile menu open it then search the message alert tone then set as you want.
Dec 25, 2009 | Cell Phones
How do I use my own music for a message alert?
- go to settings
- then phone profiles
- make sure that it is set to normal
-when in normal mode press options and then edit
- it will come up with a incomeing call, message
-select meesage
- it will then come up -melody
-message alert
- select message alert
-press options and then change you will then press change and 1 use effect tone
2 use my alert tone
-select use my own alert tone
problem solved
Jul 10, 2009 | Samsung U900 Soul Cellular Phone
On the LG VU CU920, how do you set ringtones as message alerts?
After going through the manual and talking to an AT&T rep, I found that it is not possible to set your own ringtone as a message alert tone. You can only use your own ringtones for calls and ringer ID's. We're stuck with the 10 pre-loaded rings for the message alerts. :(
Jun 02, 2009 | LG Vu CU920 Cellular Phone
Message tones on the samsung u900 soul
go to settings, then choose phone settings. In phone settings go to phone profiles, normal is highlighted click options, then edit, then ok. Click the right arrow then go to message alert tone, click on options then change and ok. Go to use my alert tone choose your tone go to options and click down and select then ok. Then job done.
Jul 13, 2008 | Cell Phones
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
64 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
