Question about Sun Mate Coldmate 854 Compact Refrigerator
Sunmate coldmate 854. I am looking where I can find a ac/dc cord adapter part for the fridge?
I've got one - will sell for te right price
Posted on Aug 26, 2012
Input voltage?
looks like it is 12 V, 1 to 2 amp.
her are some power Adapters listed on amazon. Also, look on the bottom to see what polarity it is (also by mosue over the picture of the adapter in the bottom link (to zoom in)
Amazon com Pwr Extra Long 6 5Ft Cord AC Adapter Charger for Seagate Hdd...
Amazon com Super Power Supply AC DC Adapter Charger Switching Cord Plug...
Apr 28, 2016 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I need a class 2 power Supply ac/dc adaptor
Shop for I need a class 2 power S... on Google
Phihong ? Wall Mount AC Ada...
$4.68
Mouser Electr... United Security Products AC2P
$15.44
ELVESsupply... Mean Well ? Desktop AC A...
$13.10
Mouser Electr... Ac Adapter For Black & Decke...
$17.99
eBay Generic Ac Adapter Char...
$5.99
eBay Search Results
    Kastar AC DC Adapter Plug-in Class 2 Transformer Power ...
    www.amazon.com > ... > Car Chargers
    Amazon.com, Inc.Kastar AC DC Adapter Plug-in Class 2 Transformer Power Supply Cord Wall .... Provides power to your device in the event you may have lost or damaged your ...
    Amazon.com: Class 2 Power Supply AC Adapter 6V 200mA ...
Dec 14, 2015 | Computers & Internet
It will not trurn on does the ac adapter need replacement it is over 10 yrs old
Look at adapter, see what output is supposed to be- maybe 12 volts DC? Find a multimeter that will measure DC voltage, and see if the output plug has that across the connector. If you have an ordinary power cord without an adapter, it will have 120 volts AC like any other cord, which you can also measure on AC scale, but be careful as you can get a dangerous shock, just like you can from an ordinary household outlet.
Note: AC voltage may vary by country.
Apr 09, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
DC to AC power cord Do they still make them if so under what name or product name?
"DC to AC" cords are not really a common item. They are called "Inverters". Typical inverters are 12VDC to 120VAC and are found in mobile applications to operate houshold current type (120VAC) devices. Inverters cost many times more than thier "AC to DC" or "AC to AC" sisters.
An "AC to DC" and "AC to AC" cord however, is a very common item. They are usually called simply "AC Adapters" and are sold in many electronics stores (Best Buy, Fry's, etc.) and electronic specialty stores (Radio Shack) and electrnics suppliers (MCM, etc.) Nearly all of them are designed to reduce the voltage in your home (120 VAC volts alternating current) to a different but usually lower voltage that is either AC or DC.
In order to select the proper AC adapter, you need to know:
(1) Input Voltage - this is the outlet voltage - often 120 volts in N. America, (2) Output voltage - this is the voltage the device needs and is often indicated near the jack, The adapted must match this voltage. (3) the device voltage type - this will be either AC or DC. The adapter must match the type as they are NOT interchangeable. (4) the size and type plug on the cord that will allow it to mate properly with the jack. There are many, many types and it should be tested for fit prior to plugging in and must match the device jack (5) the power requirements - this is usually shown as a number in Watts (w) and / or Amps (a). It is very important that the apdapter power rating is equal to or greater than the amount specified by the device. Failure to meet the requirements above can cause failure of the device, adapter or both.
I hope this helps and good luck!
Feb 08, 2013 | Uniden BC60XLT-1 Handheld Scanner
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
Where can I get 2 power cords fr a Colby V ZON TFDVD7006 player?
Looks like this is a discontinued item. Specs on the AC adapter are listed as:
The AC adapter operates on AC 100-240V ~50/60Hz (DC Out: 9V; DC
Current: 2.0A minimum
Your best, quickest bet is to check with a place like a Radio Shack who may have a universal adapter with the correct fittings to plug into your player.
Nov 05, 2010 | Coby TF-DVD7006
My 4520 Acer Laptop will not charge and will not work on AC power alone.......
You First need to test your AC Adapter Cord...
You can test if you have a secondary known working one.. plug that one in to see if same issue occurs.. OR you will need to test the AC Adapter using a multimeter (available at any home improvement store for under $7).. When testing the Plug End on the AC Adapter - Hold The Negative Test Prod Of the Multimeter to the Outer Side Of the Plug Tip, and Put The Positive(red) Test Prod Inside The Plug Tip... See If You Have Power Through The AC Adapter Tip... You Might Need To Slightly Wiggle The Cord Near The Tip End To See If THere Is A Short In The Cord....
If Cord Tests Good....
You Will Need To Replace The Laptops DC Jack...
The DC Jack is the port where your AC Adapter Plugs into on the laptop..
Your Faulty DC Jack Would Need to be desoldered, the motherboard cleaned of all old flux, Re-Tin The Contact Pads and then Resolder a New DC Jack Onto The Motherboard...
Nov 16, 2009 | Acer Aspire 4520-5582 Notebook
Laptop won't a hold charge when plugged in
Remove the Laptops Battery, Plug in AC Adapter... Is it able to Stay Powered On?? Slightly wiggle the Cord Near the plug end while plugged in... Does it still receive true power??? If So, Its Not Your AC Adapter Or Your DC Jack And You should Look into Replacing Your Laptops Battery...
If You Are Not Able To Power THe Laptop Using Just The AC Adapter When The Battery Is Removed, Then You First Need To Check/Test The AC Adapter using A Multimeter To See If You Have A Faulty Cord... If Cord Is Still Getting Correct Power Through To The Plug Tip .. Then You Will Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into on the laptop)
Nov 16, 2009 | Acer Aspire 3680 Laptop
Samsung ltm1755b dc cord missing/need replacement
You can order a replacement AC/DC adapter power cord for this model (LTM1755B) from a major Samsung parts distributor at the link below:
Samsung LTM1755B Replacement Part AC/DC Adapter Power Cord
Apr 17, 2009 | Samsung LTM1755 17 in. HD-Ready LCD...
Charger
The light can come in a box with just the light alone (light with battery), single ac(light with ac cord and 1 charger), single dc(light with dc volt cigarette outlet and 1 charger), double (light, 1 ac, 1 dc cord, 2 chargers) pb charger...and so on. The sticker on the box that contains the UPC code should have the listed detail on what the box should contain. Still confused check out the website www.streamlight.com search the light you're looking for and check out the product part number list. Hope that helps ;)
Jul 21, 2008 | Stinger Streamlight 75000
Sun Mate Coldmate 854 Compact Refrigerator Logo
119 people viewed this question
Top Sun Mate Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sun Mate Refrigerator Expert? Answer questions, earn points and help others
