Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker not working, yet water dispenser is
Kitchen Aid side by side KSCS 25 IN SS01 refrigerator ice maker not working, yet water dispenser is. I thought it might be the PUR filter, which I hadn't replaced in 3 yrs., so I have installed a new one. Was told it might need 24 hours to have the ice machine react....way beyond that now. The
  • jeff robinson Jun 06, 2010
    I have a kitchen aid side by side KSCS 25 IN SSO1 with a recently non-functioning ice maker, yet the water dispenser still works.
    After changing the stock PUR filter for this ref. several days ago, the ice machine is still not working. I am wondering if the blue box with two water tubes and electrical connectors could be a device that I need to replace.
    still checking out what he advised me to do, but I appreciate the ideas. :)
    President:
  • 1,561 Answers
Follow the below procedure to troubleshoot and fix your ice maker because that may not be the problem.
Inspect the water supply line for any signs of cracking or crimps in the line. A pinched water supply line can keep the water from getting to the ice maker, resulting in no ice. Check to verify that the water supply valve is open enough to provide an adequate supply of water to the ice maker.
Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a technician.
Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
See if there are icicles hanging from the fill spout and/or on the ice maker's sides. If there are, this means your water inlet valve is leaking and will need replacing. Refer to your user manual for a part number, or call a technician
Check to see if the ejector seal is cracked. If it is, replace it. Refer to your user manual for a part number, or call a technician.
Take care.
Posted on Jun 06, 2010
    Thanks for the advice, Jumuah. I'll go through those steps along with following the advice of the other responder. Appreciatively, Jeff
  • 1,284 Answers
Hi, i have the same refrigerator and was having a very similar problem. My water would dispense just fine, but the ice maker suddenly began making partial cubes of ice, then quit making ice, than started again before finally stopping again. At first I thought it was because the fill tube coming from the back of the frig was frozen, but after clearing it the problem persisted. I traced the problem back to the valve at the back right corner of the frig. I disconnected the power inputs and water lines, then took the valve apart. On the side that feeds the ice maker there is a small washer inside of the valve with a very small hole that only allows a limited amount of water flow through it. A small pieced of rubber had broken loose from another section of the valve an was clogging this small hole. I cleaned the entire valve system and reassembled it. The ice maker is now back in action!!! The fill tube going into the tray had frozen because of the small trickle of water that was going into it was not sufficient to keep it from freezing. Make sure this is still clear before turning everything back on. I hope this helps several of you out there, as this seems to be a common problem.
Take care
    Thank you, Sheikhtijani. I appreciate your insight. May I ask if you cleaned out the thumb-sized beige cylinder on the top of that blue water/ice diverter or did you plug the three water lines and disassemble the whole blue devise? Thanks, Jeff
  • Shehu Pro
    Shehu Pro Jun 06, 2010
    I disassemble the whole blue devise.....
Kitchen aid kscs25 with a small but ongoing dripping from water dispenser
Try removing the filter and reinserting it to make sure the seal on the filter is fitting flush with the filter housing assembly.
Apr 22, 2012 | KitchenAid KSCS25FKSS Side by Side...
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
485 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
