Question about ViewSonic PJ501 Multimedia Projector
The projector shows slides as purple but computer has the right colours?
  • 75 Answers
Check your cable...you are missing one of the primary colors. you could have a bent/broken pin on either the projector port or the cable or laptop port. this would be the VGA connection.
Posted on Jun 07, 2010
Once turned on, the colour that appears on screen is purple instead of white.
Check cable from computer (VGA cable is loose, or bad) one of the pins is not making contact. Try another cable, if that doesn't cure it then you have a bulb going bad.
Feb 25, 2011 | BenQ PE7700 DLP Projector
Screen is turning a pink/purple colour
You should firstly test the projector using some alternative input sources, and using different cables to establish that the pink/purple tinge is consistent across all inputs.
If it is, then your projector is in need of professional repair. You should be able to contact 3m here who can advise who their local repair agent is.
Best of Luck
Feb 15, 2011 | 3M S20 Multimedia Projector
Why is screen screen purple when playing blue ray dvd
See menu and select colour setting to get the right one
Aug 05, 2010 | LG CF181D Projector
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
Benq MP 721 projector purple colour when it projects.
You are missing one of your primary colors and this is usually to a faulty pin where you are connecting your vga cable to. It could be either the pin on vga port of your projector or it could be the vga cable itself. Please look at the pins especially if you are using one cable to try with all the compputer.
Jun 02, 2010 | BenQ MP721 DLP Projector
Optoma h27 colour issues
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
Dan
May 07, 2008 | Panasonic PT-LB10VU Multimedia Projector
Everything is purple!
Hi there
Try using a different cable , should do the trick
Apr 14, 2008 | Epson PowerLite 737c Multimedia Projector
Projector Colour Problem
Could be a few things....first you need to isolate a signal source issue or a faulty LED lamp. Simply unplug your signal source and run the menus on the projector. Purple Gone with source unplugged = faulty source our signal Purple still there = faulty device Sounds crazy but make sure you have no interference devices running real close within say 2 feet. cell phone, microwave, magnets, high voltage eletricity...etc
Jun 06, 2007 | Offspring Technologies C5YP-BIN-25 25...
ViewSonic PJ501 Multimedia Projector Logo
273 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
