Question about Frigidaire FAX054P7A Wall/Window Air Conditioner
I just installed he Fax054 frigidaire air conditioner and it is working but does not seem to be as cool as it shoul be. It's at the 60 degree mark, but feels more like 80 in the room.
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
jumptrout51
  • 3361 Answers
SOURCE: Does the Frigidaire FAC 126P1A need to be vented?
It must be installed in a window openeing or through the wall.
A load bearing wall is no problem.
Cutout the opening larger than the unit and install a header in the wall cutout.
Posted on Mar 12, 2009
roniecon
  • 6927 Answers
SOURCE: frigidaire wall unit- 4 years old air conditioner
try a fan run capacitor ,,,and the a new fan ,see if fan is stif to turn by hand if so replace fan
Posted on Jul 03, 2009
  • 674 Answers
SOURCE: Frigidaire AC 10,000 btu-not cooling very well
Make sure the filter is clean. Take the unit outside and get some coil cleaner and cleant the coils. You'll have to remove the casing. Also,rinse it from the inside outwards.
Posted on Jul 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: window air conditioner cools but doesn't dehumidify
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
I have my brand new frigidaire window ac unit set at 60 degrees Fahrenheit, so why does it only cool and keep the room at 65 to 68 degrees Fahrenheit?
if you have it set at 60 F and it is working at 65 to 68 F then that would be about right
as the air is cooled the cold air falls to the floor and out under the door, open window or anywhere else it can escape
the unit has to be at 80% room height so if it is set in a window then when the cold air gets up to the thermostat or ac level in the window then it will stop cooling
So if the ac unit is say 4ft from the floor and the ceiling height is 8 ft then the ac will only cool the bottom 4 ft
cold air does not rise but falls down
if you are using a ceiling fan then the cold air is stirred up and the 65F sounds about right
remember that the setting temp ( what you set it at) is the lowest temp that it will go down to before it stops cooling and if that is not reached it will keep working to attain that temp and if the room is too big, air leaks under door . around the fit in the window , no insulated walls , hot exterior wall,etc then maybe 65 F is the best you will get
May 09, 2016 | Frigidaire Heating & Cooling
My frigidaire Air Conditioner model Lra074at7 is not blowing cool air. Its very hot in the room I have it in. Not sure what to do??
Hello friend, thank you for your inquiry!
I understand that your Frigidaire air conditioner is not blowing cool air. There could be many possibilities to why your appliance is not cooling properly.
· Check to make sure the air vent is not in the open position.
· Make sure there is nothing blocking the airflow of the appliance.
· If your appliance is turned on in a hot room it could take additional time to remove "stored heat" from walls, ceilings, floors, and furniture.
Is your appliance under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy. I hope this is helpful. -Matt
Aug 19, 2014 | Electrolux FRIGIDAIRE LRA074AT7 6500BTU...
My frigidaire a/c is set 73fhrenheit after running for a time the temp. on the unite drops to 60 degrees by it self what is the problem ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Jul 22, 2012 | Frigidaire FRA186MT2 Window Air...
I have a Goodman CKL24-1k air conditioner. I live in a townhouse in Louisiana on the 2nd and 3rd floors. I set the temperature to about 73 degrees during the day so I can sleep bc I work the graveyard...
I lost you at my the end but the 2 ton unit should be able to cool 960 sqft. Sounds like a refrigerant problem. Air conditioners should cool the air 15 to 20 degrees. This means 80 degrees going into the machine in the return should be 60 to 65 degrees coming out in the supply. If you are in that range than it's likely never going to cool the space.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 07, 2017 | Goodman Heating & Cooling
Hi, I have a Daikin Model FTXS35D with RXS 35D 3VNB outdoor unit. Until this year it was excellent, now does not cool as before. Have cleaned filters etc. Could it be a sensor problem. When I...
Your unit should cool 15 to 20 degrees. 75 return air temp should be below 60 degree supply air temp. If you are not in this range you likely have a refrigerant problem.
Aug 14, 2017 | Cfm Daikin R410a Split System Air...
Just moved and installed my LG airconditioner. it does not cool, but warms.
Check it's in cool mode and temp setting is 3 degree less than room temp Check compressor is working with required pressure.60 PSI@ 98 degree Fahrenheit of ambient temp.If less pressure or no pressure, gas leak. Arrest leak and recharge gas.
Jan 28, 2011 | LG Heating & Cooling
The air conditioner is emitting cool air instead of cold air. I have the setting on cold and the temperature setting at 60 degrees. On these days that have been near and over 100 degrees, that cool air...
Typical temp split should be 15 to 20 degrees. A 75 degree return air temp should be in the 50s. Be sure coils are clean , if in that range the machine can do no more. If it is not, you likely have a refrigerant issue.
Aug 31, 2017 | LG LWHD1009R Air Conditioner
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
Jul 29, 2010 | Frigidaire FAC107P1A Wall/Window Air...
Frigidaire FAX054P7A Wall/Window Air Conditioner Logo
105 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
