Question about Dryers
NEED WIRING SEQUENSE FOR NEW TIMER SWITCH FOR GE PRODIGY DRYER MO#DPR483EAOWW TIMER PART #WH12X10193 THOUGHT I HAD WIRES ORGANIZED WHEN OLD ONE REMOVED BUT NOTHING WORKS AND NOW IM NOT SURE IM HOOKED UP RIGHT
ginko
  • 19396 Answers
SOURCE: Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 06, 2009
aasc
  • 1606 Answers
SOURCE: trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Posted on Sep 04, 2009
Testimonial: "Okay that worked perfectly. Timer works. Unfortunately, so does the old one."
SOURCE: Not getting heat from dryer
check the high limit switch and glow rod
Posted on Sep 15, 2009
  • 10865 Answers
SOURCE: Ge prodigy takes way to long to dry an average
chances are you have lint in the exhaust vent, exhaust pipe or the area out-of-doors.
Posted on Oct 06, 2009
  • 2468 Answers
SOURCE: New GE Profile dryer DPSE810EG7WT does not work. I
if this is a gas dryer you would only need L1 OR L2.... NOT BOTH PHASES, this unit only needs the one leg of either A 120Volts or B 120Volts phase NOT BOTH PHASES 240 volts A.C. not 240 V.A.C. as in an electrically heated element will require to heat the system, NOW ...be careful now because one hot phase is connected where it shouldn't be!!!!
Posted on Apr 26, 2010
Hi! Please help me. I am having trouble connecting the wires from my dead 220v T104 pool pump timer to a new 220v T104 timer. The old timer had posts marked G 1 2 3 4. The new one has posts marked L 1 X...
Open following link for T104 wiring diagram:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Your new timer is L 1 X 2, so that is not Intermatic T104.
You might have GE/Tork 15061 that fits into Intermatic box.
http://waterheatertimer.org/GE-timers-and-manuals.html#GE-replacement
First thing to check is if new timer is 240Volts to match old T104.
If new timer is 240V, then here is crossover:
"Old 1" goes to new L >> and notice that L and 1 are connected by brass bridge. If bridge is missing, add a jumper wire between L and 1 on new timer
"Old 2" goes to new 2
"Old 3" goes to new X
"Old 4" goes to new X
T104 Intermatic timer is SPDT single pull double throw, so it turns off both wires going to Load.
New L1X2 timer is SPST single pull single throw, so it turns off one wire going to Load, and that's why old 3 and old 4 both connect to terminal X.
If this is too complex, then add a comment or buy new trippers and a new WG1573 clock motor and repair T104 for $20.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Apr 22, 2011 | Intermatic T104 24h 208-277v Mechanical...
I have a General Electric timer on my water heater. For some reason it has stopped working. How do I override the timer. It is less than a month old?
1) GE timers don't have override switch, but if you raise all the timer segments, the circuit to water heater will be completed.
2) Open link below to identify timer and see wiring diagram, and wiring instructions.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
3) Override timer using the wires:
Take a photo of wiring so you can re-wire correctly on new timer.
There is 1 black and 1 white Line wire coming from the breaker.
And 1 black and 1 white Load wire going to water heater.
Connect black Line and Load wires together on same terminal.
Connect white Line and Load wires together on same terminal.
This will complete circuit to water heater and by-pass the timer.
4) Buy new timer at Home Depot.
Reconnect wires on new timer.
Return defective timer in new box.
Keep new timer clean, and swap out whenever needed and give yourself extended warranty.
5) This is the first report of GE timer going bad that I've seen on Fixya.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | General Electric GE 56941 24-Hour Outdoor...
I am replacing my old Lutron timer with a new GE 15070. The old one has a black and white wire. The GE has a black, white and red. Black to black and white to white, leaving the red unattached does...
You old timer was a simple one-pole switch. It could connect the black and white (that's ON) or not connect them (thats' OFF) The new timer is a two-pole switch. It is like two switches (A and B) that act opposite each other. In one position A is ON and B is OFF. In the other position B is ON and A is OFF. On your old timer the two wires were interchangeable. But on the new timer you have to know which wire is which. Since you only need one pole of the new switch there are only three combinations to try, and you have already tried one of them. All that matters is which wire on the switch you ignore. Try ignoring a different wire. That will either work or it will operate backwards (being ON when it should be OFF and vice-versa). If that happens, then the third time will be the charm. Good luck, Al K
Dec 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
15265 In-Wall Digital Timer - I am replacing an Aube with this new timer. Timer is to operate a wall plug (outdoor soffit). Timer is inside. The old switch had 3 wires - only two were connected (I think...
GE -15265 manual
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
Ah, the usual how to connect 4 wires to the old 'was-3-wire and now-2-wire' problem.
I tested and wired these timers.
Aube timer has internal rechargeable battery, and therefore does not need another wire to run internal clock.
GE timer has extra wire to run internal electronic clock, just like alarm clock is plugged in.
Heres what to do in simple format
1) Timer-green-wire connects to bare ground wire.
2) Old timer has 2 wires. Take both wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This action will complete circuit to internal clock.
4) If electric box does not have white wires described above, then connect timer-white to bare ground. This works because bare ground and white neutral both connect to neutral busbar inside breaker box.
5) Turn on electricity, push in timer door for manual override. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If light does not come on, double check that outdoor bulb is good, and that breaker not tripped.
Timer can also be reset in event of short. Reversing red and black wires will not short timer.
Add a comment of you need more help
http://waterheatertimer.org/See-inside-main-breaker-box.html
Nov 30, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
Nov 13, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
I am replacing an old intermatic model EJ341 spring wound timer with a GE15086 digital in wall timer. The old intermatic timer has two black wires from each side (I dont know which one is hot). Each of the...
GE 15086 is a 7-day programmable timer. It has more wires than spring-wound timer because clock motor runs on 120V circuit, just like ordinary electric clock. The clock on spring wound timer operated by a spring.
If I understand correctly, the old timer has 2 wires. One of these wires is the Hot wire ... and that wire will connect to GE timer black wire.
The other wire from old timer goes to Load ... and that wire will go to GE timer red wire.
Instructions on a lot of these timers say, it timer doesn't work, then reverse the two wires described above ... this is because timer only works when Timer black connects to Hot.
You can also turn on power and test each wire that came off old switch to bare ground wire. When tester lights up, that is Hot wire.
GE timer Green wire connects to bare ground wire.
Moving on to GE timer white wire. This wire is necessary for the clock to run. This wire connects to Neutral wire which is usually white. You can test for Neutral by testing Hot wire to each white wire in box ... when tester comes on, that is Neutral.
If you do not have a white Neutral wire, then connect GE timer white wire to bare ground wire. This is not code, but it will work fine until you hire electrician to run Neutral into box.
Oct 03, 2010 | GE Electrical Supplies
How to wire to attic fan? Old Sping loaded timer has two wire connections Marked LINE and LOAD . There are two Romex- Three wire cables with Black , White (Common) and bare (Grd) wires coming into this box...
OK, your new switch will require the use of a neutral wire. So you will have to do what is called a pigtail. You will have to twist another white wire in with your other white wires to attach your neutrals to your switch. Note: white wires are called neutral not common. Hook the wires that were originally hooked up to your LINE to your HOT (Black) on your new timer, and the what was originally LOAD up to the new timer LOAD. SO as far as wiring all that will change is your white wires that need to attach to your timer NEUTRAL.
Jul 10, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Bought new timer for Prodigy but thought i set the wires from the old timer in proper sequence but doesnt work so maybe wrong wires on wrong terminals
Look at the wires. They have markings on them that match the markings on the timer. Did you check the Non-resetable limit? If it is open the dryer will not run.89819b0.jpg
More here
Jun 06, 2010 | GE DVL223EBWW Electric Dryer
Trying to replace timer 8299771. Can't find my
Sep 04, 2009 | Dryers
Dryers Logo
Top Dryers Experts
