Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
DSL problems i have a dsl box two outer lights are green but the ethernet light in the center bliknks all the time. cannot stay online long how do i fix it
  • 3 more comments
  • joecoolvette
    joecoolvette Jun 06, 2010
    Could be the Ethernet card is going bad. If it is Onboard Ethernet, where you plug directly into the motherboard, and not a separate Ethernet card, you could buy, and install an Ethernet card.
  • summershere4 Jun 06, 2010
    i just bought this compaq computer last week. everything if fine except the ethernet light is blinking all the time. it is orange not like the power and dsl which are green
    i cannot stay online very long
  • joecoolvette
    Not all Ethernet card manufacturers follow that. A blinking green light can mean that the Ethernet card cannot communicate properly, and there is a physical problem.
  • joecoolvette
    http://www.tigerdirect.com/applications/...
  • Dell Master
  • 11,800 Answers
You don't , it's normal, the led blinks to notify you that it transmitting data. You should worry when it doesn't do that = you don't have a connection to the internet.
Posted on Jun 06, 2010
  • Azrael SRL Jun 06, 2010
    Simple test: disconnect the LAN cable from the dsl box to the pc -  both leds (from the box and from the LAN jack of the pc) will stop lighting/pulsing. Again, this is normal behaviour.
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
My dsl light is on green but my power light is on red. After a while no lights are on. My router is a 2wire that's about a year old
These 2Wire devices are known to have their wall-wart weaken over time. Although you can measure the proper voltage coming from the wall-wart, when you load it with the DSL modem, the actual voltage drops giving you the red power light. The green DSL light may or may not be accurate while the DSL modem is not getting the power it needs. Look online or go to a store like Radio Shack for a replacement wall wart.
Aug 26, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Ethernet light went off and won't come back on
I had the same problem. It seemed the modem reset and the address changed. I called my ISP (Verizon) and explained the problem to them and they had me online in no time.
Hank
Aug 21, 2009 | Computers & Internet
2WIRE 2701HG-B with flickering DSL light.
The DSL is out in your area or the phone line has been disconnected.
I would contact ATT&T to find out if thire is a service issue in your area
Aug 15, 2009 | 2wire Computers & Internet
My modem sometimes work and sometime show only two lights i.e. power and ethernet and do not connect to my dsl internet
Do you know if you have line issues with your phone company? If you're at the outer edges of DSL range from the Central Office, your connection might be dropping. The fact that the power and ethernet lights stay lit shows that the connection might not be on your end. Does the connection get reestablished when you reboot the modem? You may have to get your provider to do connectivity tests on your line.
Jan 04, 2009 | Computers & Internet
Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
Dec 30, 2008 | Westell Wirespeed VersaLink...
Installing My New Motorola dsl modem
hello!
-- what is the model and brand of your modem?
-- who is your internet service provider?
-- is your account activated?
-- do you have a username and password from your ISP?
-- have you tried changing cables? what about the phone port?
May 08, 2008 | Computers & Internet
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
Alun Cox
