Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Leakin gas tank on Mod #PM 425 AV-18
Gas tank leaking, require either new tank or compound to stop leaks, any ideas?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Try sealing with PermaChem (I think that what it's called). It's a thick, sticky, fuel resistant compound that some in a small 4 oz tube. It never really hardens. It's made for threads. If this won't work than try Seal-All It will harden & should seal a cracked fuel tank, temporary fix for a fuel hose leak, etc. It can be found at Walmart, Home Depot, etc.
Posted on Jun 06, 2010
The new bike leaks fuel in overflow hose only drive 10kM after bought
If the tank was completely filled with cool gas, and the bike was parked in the sunshine, the gas in the tank warming up may have expanded, pressurizing the gas tank. Gas caps are supposed to be vented to allow air to enter as the fuel is used, but they don't stop the tank from having pressure inside. Try removing the gas cap to see if the leaking stops.
I suggest that you call the dealer that you bought it from and confirm the problem..
Mar 13, 2015 | Motorcycles
My 2000 buick lesabre is leakin gas under the car from lines conected to the tank running to the engine
You just have to figure out where it is leaking and repair it. Cut out the bad part and use compression fittings and new line. The supply line is 3/8 inch and the return is 5/16 inch.
Nov 05, 2014 | Cars & Trucks
Oil leaking
Defective fuel shutoff valve. Some can be rebuilt, others must be replaced. Use same kind if replacing.
Stuck float in carburetor. Does it run good?
Apr 01, 2014 | 1988 Honda NSR 250 MC 18 SP-R
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 09, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Gas leaks out when chainsaw is tilted and in use
sounds like you have a cracked fuel tank or stripped out gas cap
Apr 13, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Oil leaks out of chainsaw when stored
thats not uncomon mine leaks as well,,if your going to store it away drain the oil tank dry first
Nov 28, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a 2000 kawasaki ZR750 with a gas leak
the gas tap has a diaphram and plunger to turn off the fuel when the engine is stopped, this may be dirty, worn or the diaphram gone hard. If dirt has got into the carbs it must have gone through the gas tap.
clean it or get a gas tap rebuild kit
Mar 31, 2010 | 2002 kawasaki ZR-7 S
Gas Water Heater leaking
If the tank is fairly new you me able to reseal the leaking fittings. You will have to turn it off and drain, then remove the leaking fittings and reseal them with pipe joint compound or teflon pipe tape.
Aug 14, 2009 | Rheem Gt199dvn Heavy Duty Tankless Water...
Front gas tank leaked when I filled the tank
the top of the tank has an opening where the gas guage sending unit is installed. The gasket can give out and it can leak when the tank is completely full, but won't necessarily show signs of leakage when the tank is partially full.
Requires dropping the tank and changing the gasket... hope this helps.
Apr 20, 2009 | 1997 Ford F250 SuperCab
Gas leaking from carb
You have a stuck float in the carb.
Jan 11, 2009 | 2006 Husqvarna TE 250
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
172 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
