Question about Plumbing
I am constructing a pool rail using pvc pipe and various pvc connectors. What tips are there for fully seating the threaded connections? I have always found that when it comes to joining the threaded components, I can never fully tighten the two pieces joined such that each end fully meets.
  • 65 Answers
Use pvc joint compound purple...it mends the plastic together,,also if you feel the pipe with sand it drasticly stablizes the pipesand makes them harder to break
Posted on Jun 06, 2010
  • 623 Answers
I don't know if they are designed to "meet", aren't the threads a taper fit?
How to replace fuel pump on 2005 chevy monte carlo
The pump is in the gas tank, so the tank has to come out.
Apr 28, 2016 | Cars & Trucks
Intex pure spa- intex inlet oulet o- ring is out of stock till who knows. Can you use another type. Photo shows end of pipe 1.25".the o ring sits at end of pipe.
try putting an o ring at top of threaded areas or PVC glue together or cut off threads and put mission coupler on it
Jun 04, 2015 | Intex Pool & Spa
I have installed a new pb4 pump and it keeps blowing off the hoses on the top side out to pool. I have checked for obstrustions in lines, I have siliconed my connections, i have lowered my psi thru return...
I assume you are talking about the flexible hose that is connected with a threaded collar and clamp the hose to the fittings.This can be caused by vibration, warn parts, high pressure or collar not tightened sufficiently. If the parts were installed with the previous pump then they may be worn. If you tried replacing the the fittings then you may want to change the parts to PVC fittings and piping instead. About half of the booster pumps I have seen were connected using PVC piping. I hope this helps.
Aug 22, 2011 | Polaris Pb4 - 60 Booster Pump
Emerson pool pump, pvc pipe between impeller and strainer snapped, how do or can you replace the pvc pipe, it appears both ends are glued
You can buy what is called an internal connecter that fits inside the pipe and glues the two halves back together. It is a specialty pvc fitting not found in home improvement stores. You will likely find them at a local pool service company.
They look like this. They are on the top right with part numbers like S0302-15 for 1.5" pvc pipe.
John
Nov 28, 2010 | Emerson Pool & Spa
I have a small leak on my Raypak 2100 inlet pipe. It's coming from the pvc joint to the cpvc connector so I'm thinking it's a small crack that has developed over age (heater is ~12 years old). I'm...
You can run 2" all the way if you want. I f you have 1 1/2" coming from the filter you will have to bush it down at some point.
If it comes from the filter in a larger size it will be best to run that size to the heater but 2" probably wont hurt.
Sep 04, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Looking to buy pvc pipes to fit Jandy pool heater in and out flow pipes live in slough uk
jandy in and out pipes are 2" schedule 80 cpcv and should beavailable at any plumbing supply house. buy on 16" nipple and cut in half.Thread into headers then pvc cement the unthreaded end to tie into pump/filter system
Aug 21, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Bathroom drain pipe has no threads
I 'am having a hard time visualizing this problem ? is your drain line a PVC pipe or is it the old style brass that was once used?
Jul 26, 2009 | Plumbing
Need help downsizing pool pump connection
Okay. I think I gotcha covered.
I have one mocked up here right in front of me.
Still going on the PVC pipe assumption...
- Install a PVC 1 1/2 " - 1" reducer on the new pump nipple.
- Install a short piece (nipple) of 1 1/2" PVC pipe in the reducer installed on the pump
- Install an 1 1/2" MIP adapter (PVC) on the 1 1/2 " nipple
- Screw the hose onto the threaded 1 1/2" MIP adapter.
There are several ways to do this -- the above is a good way.
Have you ever mated PVC piping/adapters with solvent? I can help you with the details of this if your unfamiliar with it...
Charlie
May 29, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
Inlet pvc pipe broke off and is in face. is pvc threaded or not?
Get a screwdriver (or something strong like that) that is the diameter of the pipe only. Use a torch to heat it up and then press it into the pvc...might take a couple times to get a good indent, and then turn....it is threaded 3/4" pvc....some installers will actually glue this fitting in the pump - which render it unuseable in this situation....
Mar 28, 2009 | Polaris Pb460 Polaris Booster Pump...
Plumbing Logo
74 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
