Question about Car Audio & Video
I won,t to remove radio/cdplayer from a fordfreestyle2005
  • 518 Answers
There should be a plastic trim over outside edge of unit held in by spring loaded clips &/or screws. If you dont see holes for screws then its just clips. Carefully pry up on outside trim. The unit will have a hole in each corner. It will require a ford radio removal tool. It is 2 u shaped pieces that will engage into the 4 holes click then unit slides off of track outward.
Posted on Jun 06, 2010
Cd player sounds like it is fast forwarding
Sounds like you have two diff connections hooked together
Sep 03, 2012 | Sirius Satellite Radio Receiver
Need to install a cdplayer in 70 chevy truck?
Because of the year of the truck you will not have any wires pre-wired in the truck, go to a Radio Shack, car audio store or Best buy and buy yourself some speaker wire for vehicles, about 5 ft of 14 - 16 gauge yellow wire, 5 ft of 14 - 16 gauge red wire a couple of 10 amp fuses and 5ft of 4 gauge black wire.
You are going to run the Yellow, Red, Black wires together from the radio space where the radio sits in down to your steering column, the speaker wires will go to your speakers from the radio, a + and a - lead to your speakers and connect them as needed.
Now back under your dash you will connect the yellow wire from the radio to the 12 volt + wire under your steering columns 12 volt power wire with a fuse inline, if you hook up a test light to this wire it will light up the test light without the car switch being turned on, the red wire will hook up to your ignition switch wire and your balck wire to the vehicles ground chassis, basically ground that wire to a non painted surface of the vehicle. This radio needs to be hardwired like I explained.
Good luck and hope it helps.
Lex.
May 21, 2010 | Car Audio & Video
How do i turn on the cdplayer? and remove the cd
More information please. If this is an internal CD drive in a PC, you typcially will power on the pc and hit the eject button on the face of the drive.
Also, if your running Windows, and the CD is seen under My Computer (if XP) or Computer (Vista & Win7), you can right click on the drive and select Eject.
Dec 25, 2009 | Gateway Computers & Internet
I have a jammed cd in the stock cdplayer in my
You can pry open the door, the pull back open as far as it will go, remove cd, press eject button and see if the system corrects itself. If not, you probably have a faulty capacitor in the unit.
Oct 13, 2009 | 2000 Lexus RX 300
My 04 seville cdplayer was stolen. I purchased 1
I hate to say it, but you'll probably need to see the dealer for the programing steps and code. Unless a local locksmith is able to reprogram the security system, the dealer will have to.
Jul 30, 2009 | 2004 Cadillac Seville
Code for radio/cdplayer 6000 CDRDS Ford Focus
Remove the radio from the dashboard and quote the SERIAL NUMBER....normally begins with M * * * * * *
Apr 24, 2009 | 2001 Ford Focus
Swap radio
It should as they are Both Double Din Units. The Larger Head Units from GM.
Jan 22, 2009 | 2001 Chevrolet Impala
Car cd player into Fiat punto
Sorry to say, but it it sounds like it's defective. If it's new you should return it for an exchange.
Geno
Feb 26, 2008 | Radio Communications
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
