Question about Goodman GPC1330H21A Air Conditioner
Fan wire caught and shorted out, is there a reset on a Goodman A/C unit, repaired wire, fan running but not unit
  • 674 Answers
If you are talking about the outdoor fan then if the fan is running the compressor should also be running. First check the capacitor and make sure no wires got pulled off. Some units use a 2 pole capacitor that runs the fan and compressor. The terminals will be Com, Herm (compressor), and Fan. If no wires are pulled off then check the capacitor and make sure the surge didn't ruin it. Let me know what you find or if you are talking about the indoor fan.
Posted on Jun 06, 2010
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Indoor fan keeps running
fan relay is bad usually this is the board or wires are shorted. take of the green wire at unit does it keep running if so fan relay is bad
Mar 27, 2013 | Goodman CPLT24-1 13 Air Conditioner
Can an electrical short in one of the wires to the inducer fan motor be repaired on goodman gas furance
Sounds like you just have a loose connection. Make sure all the wires are connected and tight. Make sure power is off to the unit to prevent electrical shock.
Feb 12, 2013 | Heating & Cooling
Goodman A/c not cooling the fan not turning .what do I need to do?
If its the outside fan not running check the breaker and the fuses in the disconnect(some may not have fuses) if that is not the problem but you can hear the compressor running it could be seized fan motor, failed capacitor, faulty contactor, bad wiring. Turn the breaker off to the unit and try to spin the fan with a long screw driver or something similar but be careful not the bend the fan blade, If the fan will not move don't force it you need a new motor,If the fan spins freely move on open the cover and check the wiring but becareful the capacitor can still have a full charge and shock you even with power off. Other the that you will need a volt meter that can check volts, amps2_bing.gif, and capacitors to futher test the unit I suggest calling a local HVAC contractor and having the unit repaired and tuned up, by having a tune up done you can recoup the cost of the repair with the energy savings from the tune up.
Apr 02, 2010 | Goodman CKL36AR36 Air Conditioner
My Goodman a/c unit will not turn on ..
You have a short circuit in the outside system. Either a bad compressor,bad fan motor or possibly a bad capacitor. Visually examine the capacitor. If it is bulged out anywhere,replace it. Check for burned wires on the capacitor and all other connections.
Remove the compressors wires from the circuit and restart the unit. If the fan runs the problem is in the compressor. If the fan does not run,the problem is with the fan motor.
Jul 20, 2009 | Goodman CKL42AR42 Air Conditioner
AC Fan outside running slow
The brown wire goes to the capacitor. It probably shorted out with the nicked wire. Replace the capacitor.
Jun 29, 2009 | Goodman CKL36AR36 Air Conditioner
Goodman Draft Induction Fan Keeps Cycling On and Off
can you write down where the low voltage t stat wire go and disconnect the white wire at the unit to eliminate a short between the white wire and the red wire usually the colors are as follows red is 24volt , green is fan , white is heat, yellow is cooling I want to narrow down the red is not shorting to the white briefly let me know if this is possible if not we can try other checks
Jan 06, 2009 | Heating & Cooling
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman GPC1330H21A Air Conditioner Logo
101 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
