There is a high limit switch (looks like a button with two wires hooked to it) on the bottom of the vent frame. When the vent fills up with lent at the bottom it gets hot. For safety, this limit switch will turn heat off. Remove the vent frame and clean it out and check the continuity of the switch. Also, make sure both heater elements are working properly.
If your dryer is clogged up this will not produce heat inside the dryer but will produce heat to the vent tube. Try unclogging the Vent tube and see what happens.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Make sure your vent screen is clear of lint, You should also check the actual vent duct which comes out the back of the dryer. It sounds like there is blockage of dust and lint which is not allowing the dryer to properly heat up.
