Question about Watches
Pocket watch,how much does it cost for a cleaning? watch is in need of good cleaning and oil,railroad watch cir 1920
    Genius:
  • 1,970 Answers
Mcdevito75 Here, Most Jewelers would charge Approx. $60.00--$85.00 to clean, oil and adjust your pockey watch. Check here on Fixya for one of our members who can do this service for you.
Posted on Jun 15, 2010
How to set the time on a John Allen railroad pocket watch
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. Be careful if you decide to do it yourself as the knob is fragile.
Apr 11, 2016 | Watches
My Seiko railroad approved bracelet solar power watch stopped, how do I get it running
the advice is to buy a new one, no one is fitting the batteries to these, due to the high part cost.
even if it's in warranty, seiko just send a new watch out.
Apr 23, 2015 | Seiko Watches
Wil not run
Could be a lot of things. Cleaned and oiled isn't the same as overhauled. A bad cleaning will just move some particles out of the way, temporarily. Eventually, they can stop a watch. A part could have broken during the cleaning. You may have "over wound" (jammed gear) the watch and it's stuck. So, sorry, but no single answer. Yesterday, I bought a watch that was supposedly cleaned. I removed the back to authenticate. It was dirty. So... A reputable place is important. Size of store or advertising is not. Do some checking. Good watchmakers are hard to find.
A good watch overhaul can cost at least $125 and well over $600 on higher end brand name watches. Average is about $160 at retail.
Apr 19, 2014 | Elgin Watches
My automatic omega watch stops after 20-24 hours eventhough i am promised it should last for 48hours if worn continuously for 48 hours.
Almost all automatic wristwatches made today have an 18-24 hour "power reserve" when fully wound. A 24 hour reserve is actually very, very good. I can't think of a modern self-winding wristwatch that has a 48-hour power reserve because that would require a super-long or much larger mainspring than would fit in a modern watch movement / case. There may be some hand-crafted or super-premium watches that can do this, but only a very select few.
Manual wind railroad pocket watches, which were some of the finest and most accurate mechanical watch movements ever made, generally had a 40-hour power reserve. That extra capacity was created by using a large mainspring to store the extra energy. These mainsprings could be used because of the much larger size of these watches, compared to modern wristwatches.
If you are concerned about keeping your watch ticking, even when you're not wearing it, you might want to look at a "watch winder"--basically, a small watch case that rotates the watch for you, keeping the automatic winding rotor moving and the watch ticking. In addition, sitting at a computer all day will wind your watch much less than walking and otherwise moving around. Even though you're wearing your watch, if you're not moving, you're not winding it.
May 09, 2011 | Watches
How do I go about finding a good restorer for a Hamilton vintage railroad grade pocket watch
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
Feb 25, 2010 | Watches
How do I open a medana pocket watch?
First -let's check out what type of watch you have. If you push the crown in and it turns freely back and forth with no resistance at all - this is battery driven watch.
If you do the same and feel and hear some clicking and resistance- this is mechanical (spring driven) watch.
Next - the case: Usually all pocket watches have snap-on casebacks. Take an eyeglass and examine the case. Even if you think there is no any grooves or gaps- try to pry it using watchmakers caseback opener (about $5 on ebay).
In case if there are no chance to open caseback - that means you have one of the cases assemblad watch glass fitted last and that means you have to take glass out first and then only to get to the movement.
As you will not be able to get the glass out without braking it, the only solution will be to visit your nearest watchmakers shop and ask for help.
Rate, please.
Jul 22, 2009 | Avalon Medana Gold-Tone Open Face Railroad...
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
Mar 19, 2009 | Colibri Mechanical Collection Pocket...
Watches Logo
409 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
