Question about Sanyo Televison & Video
Lamp Blown on Sanyo PLV65WHD1 LCD TV after 1 week
I have a Sanyo PLV65WHD1 LCD TV. I replaced the lamp in the unit and it work for about a week. After that time frame, I heard a loud pop and found that the lamp have exploded. I am leary of buying a new lamp for fear that it will happen all over again. Any suggestions?
  • 579 Answers
SOURCE: Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Posted on Dec 31, 2007
  • 579 Answers
SOURCE: projection lamp burn out
Hope ya fix it!
Posted on Jan 07, 2008
  • 86 Answers
SOURCE: Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Posted on Oct 17, 2008
  • 108 Answers
SOURCE: panasonic pt-lc13 MARCH 30 2008
replace yhe lamp ballast
Posted on Jan 13, 2009
SOURCE: Hitachi 50V500 won't turn on, replaced lamp, worked for 3 days
I have volume but no picture
Posted on Mar 21, 2009
The orange coloured sanyo ultra short throw DP PLC - XE50 is cleaned regularly but still the unit doesn't allow the bulb to work.
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Aug 15, 2013 | Sanyo Office Equipment & Supplies
After replacing the lamp in my sanyo projector, how do I get the lamp replace indicator off?
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
have a nice day!
Feb 13, 2012 | Sanyo Office Equipment & Supplies
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
My sanyo PLC-sw20a lamp does not light after turning on, the red lamp indicator still lighted and there is no indication for lamp replacement. Is the lamp busted?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
May 20, 2011 | Sanyo PLC-SW20A Lamp
Looking for replacement lamp for Sanyo PLV-WHD1 TV Lamp type # POA-LMP96 service parts # 6103227382. Need some help finding one that is compatible for reasonable price.
You can get replacment lamps for this TV from www.TvRepairKits.com
Models Supported = PLV-55WHD1, PLV-65WHD1, PLV55WHD1, PLV65WHD1 ,PLV-55WR2C, PLV-55WR2CH POALMP96 , POA-LMP96 , 6103227382. and more.
Feb 03, 2011 | Sanyo Genuine Original 6103227382 ...
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
have a nice day!
Jan 24, 2011 | Sanyo FOR PLC-XE31
Looking for a POA-LMP76A lamp and price
Call Encompass Parts 1-800-638-3328 and Look on E-Bay under Electronics.
Feb 14, 2010 | Televison & Video
TV picture and sound goes off--leaving a blinking green light showing as on (power). Several times in the last week I have shut the power strip off and then on again and the TV went back on with the solid...
If TV goes off and the led stays blinking, that is because the TV is going on protection.
Protection is a special diagnostic mode that starts when an internal fault has been detected.
If this happens erratically while you are watching TV, then parts that can commonly cause the problem are PSU board, main board or digital board, ballast board and converge board on DLP, inverter on LCD, low buffer and sustain boards on plasma.
May 14, 2009 | Televison & Video
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Televison & Video Logo
66 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
