Question about Tyan Tiger MPX S2466N-4M Motherboard
Nothing coming up on the monitor
I just bought a motherboard off ebay i have wired it up correctly but nothing coming up on the monitor, it turns on ok i have tried everything i can think of please someone help!!
  • 39 Answers
This is very difficult to troubleshoot because there are too many unknowns.
Does the mobo have diagnostic LEDs? The changes in indicators would indicate the boot up activity is taking place. If you have no visual indicators, then
You might have to get a boot up code display. This is a device that connects to the bus (via pci / pcie slot in most cases) and has a digital readout. When the mobo stops on a certain code, you will have to lookup the code to determine where it's getting stuck.
If you have no access to a diagnostic card, then some of the other very "elementary" things you can do are:
Listen for the beep code. If the speaker doesn't beep at all, then your CPU is likely not running the POST test. Check your power on LED. Check your HDD LED to see if any disk activity (hdd detection) takes place.
Other than that, you're SOL without some equipment.
Posted on Jun 06, 2010
Testimonial: "thanks for the advice it was very helpful"
MY computer will not power up. I have tried pushing the power but nothing. The monitor lights up though. Any suggestions?
Generally a power supply failure. The monitor has either it's own power supply or is fed by a different circuit from the computer.
Dec 15, 2015 | Acer Aspire Computers & Internet
All the components are working properly but i am not getting anyh display on my monitor i replaced every thing and checked my monitor is working ram is working cpu fan is working power supply is ok smps is...
1- evolve the battery.
2- install it again but upside down.
3- turn on the PC.
4- wait 15 seconds.
5- turn the PC off.
6- install the battery correctly and enjoy. please rate.
Jan 17, 2011 | Mercury P4VM800M7 Motherboard
I turn computer on blue light on computer tower comes on monitor power **** turns blue and the on screen message going into power save mode and then nothing change motherboard battery and took out graphic...
Short of it being something simple like your monitor cable is unplugged, the more likely problem is that there's a fault on your motherboard or graphics card.
You should have an internal speaker connected to your motherboard, it should be giving beeps depending on what the problem is. If everything is ok then there should be a single beep.
If you are not hearing anything try removing your RAM and boot up, you should get lots of loud beeps, if you hear nothing then it's likely your motherboard is faulty.
Apr 05, 2010 | Dell Computers & Internet
I had to take my computer in for repair and turned the acer monitor off while the tower was gone. After plugging everything back in after repair, the monitor will not come on when you hit the power...
The first thing to check is , the Power, are ya sure it's plugged in OK, are ya sure that socket is working, try something else in that outlet to prove, check the power cord is pushed right in, Check ya on the right Video connector on the PC, make sure all conns are correct. Try the monitor on another base unit, try your base unit on another monitor. If all these are OK then ya Monitor has turned it's toes up sorry.
Jan 20, 2010 | Acer AL1914 19" LCD Monitor
Toshiba Sattelite a135-s2276 turn on fan working but no display
I think some cooling devices on your laptop stopped working which might have lead to Motherboard problem due to heating.
Jun 22, 2009 | Toshiba Satellite A135-S2276 Notebook
How to disable the onboard graphic card when nothing comes up
Its not a problem with integrated graphic or PCI card. Sometimes if the keyboard or mouse fails, the display won't come on. Check by using a working keyboard & mouse(also check for any nent pins in the Ps2 jack)..........sodeep
May 11, 2009 | Asrock K7S41 Motherboard
Hp pavilion ze5500 display monitor still doesn't work
IT could be a motherboard problem with the function key that controls the switching of the video infomation between the LCD screen and the external video connector.
It could be the function key circuitry on the motherboard that controls the back lighting levels on the LCD.
Jan 31, 2009 | HP Pavilion dv6000z Notebook
Computer Does not Boot correctly, Monitor is Black.
try to reinstall the OS..if it doesn't work then there would be a problem with ur motherboard becaouseof failure of IC's. So contact the service men.
Sep 27, 2008 | IBM Aptiva E 240 (2158240) PC Desktop
Monitor light blinks
have you tried hooking the monitor up to a known working motherboard video or video card in a motherboard? it sounds like you may not have the settings in the motherboard correct jump the cmos clear to reset the motherboard connect everything then turn on your monitor then turn on the computer and get back to me in this thread.
May 05, 2008 | Computers & Internet
K8NGM2 Mother Wont Power Up
I've seen situations similar to yours several times and they've always been a bad CPU.  Since you tried a new video card it's not that, I would suggest a new CPU.  Check on ebay, you can usually find used one's on there.
Oct 10, 2007 | ASUS A8N-SLI Motherboard
Tyan Tiger MPX S2466N-4M Motherboard Logo
240 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Robert Graf
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
