Question about Garden
I need to replace a mower deck belt on my exmark zero turn mower and there is a place where the belt is trapped by a metal plate bar that connects 2 pulleys. Do I have to remove a pulley to release the belt? Do I have to take the spring off too? Can someone walk me through this belt change, my old one is all chewed up.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
There will be one or two "idler pulleys" besides the spindles that turn the blades. Usually one idler pulley is mounted on a plate that swivels, pulled by a strong spring, to put tension on the belt. The other idler pulley is usually fixed in place. Use strong pliers (vise-grips or channellock) to pull the spring out of its notch at one end, releasing the tension. Then the belt can be threaded. Now you have to restore tension by by pulling on the spring and anchoring it on that swivel plate again.
Posted on Jun 06, 2010
I want to change the band that moves the hydraulics of a exmart 2004
Posted on Aug 24, 2010
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Why exmark loses power when blades are turned on
Check for clogged deck.also inspection of mower deck belt. Check for glazing or cracks in belt. That will slow blades down.
Jul 28, 2014 | Kohler Engines NEW 25HP KOHLER ENGINE...
How to replace steering belt on zero turn toro lawn mower
if you mean a drive belt (not a mower belt) then im sorry to tell you your gonna need to remove the mower deck , this is only possible with help of a small crane or a stout tree limb and a bit of chain or cable (rope not good enough) , use a breaker bar to move off tension roller and fish belt around pulleys then let tension arm back down (four hands really make this easy) then lower machine back down onto cuter deck and make sure belts and pins line up right
May 16, 2014 | Troy Garden
Husqvarna 48 in zero turn deck belt replacement
drop the deck to it's lowest level and replace the belt. you will have to remove some guards on the deck for access to the belt.
May 11, 2014 | Husqvarna Zero Turn Mower Z5426
Where do the springs connect to? On the deck of my Craftsman Lt 2000 riding mower.
main one u need is the one on the engage pulley, it connects to pull plate and the center of the mower deck in the hole in deck. the one foe breaks go to brake bar and belt guid bolt in most cases
Sep 24, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
White LT-12 lawn tractor 139-656-190 Mower deck on right side is out of alinement. Rear tire rubs on deck when lowerd. How do I ajust the deck?
I have exact same problem with my 1989 built LT-12 White tractor ! I Discovered that the Right side connecting Link #14802A,that connects the lift handle shaft #17154A with the Stabalizer bar #16465A, was broken where it connects with the Deck Lift handle shaft.
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Hit a peice of metal, now mower won't engage.
The mower engages by an electronic clutch. If it doesn't squeal/smoke/start the mower deck when you try to engage the mower, then the electronic clutch is faulty (you may have sent shrapnel into the clutch), or the belt is cut or damaged enough not to drive the deck. If this problem is indeed associated with the mowing metal problem then you need to visually check under the engine - that's where the electronic clutch that drives the mowerdeck is located. You'll notice that there is a drive belt that goes from the engine to the mowerdeck. That's your drive belt. You should loosen the belt and check the mower deck to see if you can rotate the drive pulley and in turn this rotates the blades (of course you do this with the engine off). That would determine if it's the deck or the clutch that has issues. Your instruction manual will show you how to loosen the belt then try to spin the mower deck drive pulley. If it spins by hand then look back toward the clutch. If the deck doesn't rotate then it needs to be removed so you can flip it belly up to see what's hindering the movement. These decks clog easily, but if clogged when you try to engage the mower deck it will squeal. They're easy to remove (if you have some kind of overhead lift - if not they can be a pain). Good luck
Sep 18, 2009 | Garden
Garden Logo
3,787 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
