Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
MFC-5860CN poor print test results, missing squares on test resu
MFC-5860CN problem with printing the black and one of the colours missing some of the squares when a test print is carried, I believe the print head is faulty as I have carried out cleaningproceduers 5 times but only getting poorer results. where can i buy lk1279001 print head assembly or is there another way around servicing the prin head?
This can happen if the ink dries out for a long time. Try to power flush the color that doesn't work.
Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
press 7 then 6 then 4 then start black copy. This will fill the tubes with ink.
press 7 then 6 then 3 then start black copy. You may use the right arrow to choose the color you want to flush before you press the black copy button.
Press 99 to exit maintenance mode
Press the ink button and do a test print for print quality and see if the color you flushed works. If not, try again.
This is the only way to fix the dried print head. Otherwise you have to replace the print head, in which case, you might as well buy a new printer.
Posted on Dec 10, 2010
Hi i have the same problem, is the system clean the only answer here, was this resolved?
Posted on Jun 26, 2010
  • 39 Answers
I am not sure these have removable/replaceable printheads. I have had issues similar to what you describe. If one of the colors is missing completely, then it is likely that the head dried out due to prolonged lack of ink. If only a few squares are missing but all the colors are present, then you stand a better chance of unclogging. Cleaning 5 times is nothing. I've had instances where it took 20+ cycles to get a jet working. There is hope.
Posted on Jun 06, 2010
When i test print all colours show apart from black ink on paper?
If deep cleaning does not clear the black print head then a new print head is required. The cost of print head is expensive and it maybe better to buy a new printer.
Oct 15, 2012 | Brother MFC-5890CN All-In-One InkJet...
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    How do I manually clean my HP C7180 printer print head. The black ink prints with horizontal lines through it and is also very faint in colour. I have carried out print head cleans and alignments through...
    By manual you mean that it needs windows to clean it right? (you cannot physically clean it yourself) Go to your printers, right click and in properties somewhere you should find "clean heads" somewhere. Try print test after. Should be good.
    Mar 05, 2011 | HP Photosmart C7180 All-In-One InkJet...
    Brother MFC-5860CN printing issues after switch Win2k to WinXP
    Are the settings in the print driver set to the highest quality setting? If so, this will slow the print speed down tremendously. Try changing the default settings in the print driver to a lower quality (or resolution) setting.
    Dec 20, 2009 | Brother MFC-5860CN InkJet Printer
    Ink well cleaners
    There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
    Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
    My copy prints come out blurry after changing ink cartiges
    Try this:
    Checking the print quality:
    1. Press the Ink or Ink Management key on the control panel.
    2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
    3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
    4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
    5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
    6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
      If you can see missing short lines, press 2 (NO) and go to Step 7.
    7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    8. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
    9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
    10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    Setting the Alignment:
    3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
    4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
    5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
    6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
      If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
    7. Press Stop/Exit.
      If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
      Thanks, Joe
    Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    Black cartridge doesn't print
    you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
    refer to your user manual or let us know and we will find the procedure to do so.
    i have a similar model and know how picky they can be.
    Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
    Brother MFC-240C
    2nd first:
    Yes. You should print a alignment test print and follow the instruction which is given on the test print.
    I dont understand the first complain:
    Do you miss several first squares or do you miss just one?
    The latter one is no prob. You can ignore that. The first one (several 1. squares missing) is a serious prob: This indicates that a whole channel is defective!
    Did you do a cleaning procedure and check the squares afterwards? If not do so. If you still miss the several 1. squares the ph needs relacement.
    Dec 10, 2007 | Brother Multi-Function Center MFC-240C...
    Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
    390 people viewed this question
    CheckitRight
    CheckitRight
    Ron Dufek
    Ron Dufek
    James Cagle
    James Cagle
