Question about General Electric WCSR4170D Top Load Washer
My wcsr4170giww will not spin.
My wcsr4170 washer will not spin suddenly. There is no operation error involved, and it drains just fine, but there is no agitation or spinning.
fixinit4me
  • 10 Answers
SOURCE: Washer won't spin or drain.
This site may help:
http://www.repairclinic.com/0088_11_1.asp
Posted on Oct 28, 2007
SOURCE: 98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Posted on Dec 13, 2007
jumptrout51
  • 3361 Answers
SOURCE: Washer does not spin or agitate at all. Timer works.
Check your belt. It may have become loose.
On the top right and left of the front panel insert a putty knife about 3 inches in where the top meets the front panel.
This will release the front panel so that you can see the motor and belt operation.
Better still, a 5 month old machine call for factory authorized service.
Posted on Feb 24, 2009
  • 107 Answers
SOURCE: Kenmore washer will not spin or drain water,agitate works fine
Sounds like a lid switch. there should be a hole under the lid on the right side about the size of a dime. Make sure the plastic "flipper" is inside and "clicks" when you push down on it with a pen.
Posted on Apr 22, 2009
localwonder
  • 6784 Answers
SOURCE: FILLS WTANK WITH WATER AND DRAINS BUT DOES NOT AGITATE NOR SPINS
Hi. your timer assembly is faulty. it is not initiating the spin and proper wash cycle due to this malfunction. the timer is responsible for the actions and commands. if its defective, it will not carry out the initiations correctly.
CLICK HERE TO BE DIRECTED TO THE PURCHASE PAGE FOR YOU REPLACEMENT TIMER.
Posted on May 23, 2009
Error code e15. doesnt seem to be spinning
Hello. Is your washer draining properly? If there is water left in the drum you will get an error. Fixing this involves removing the front inspection cover and cleaning the filter.
May 26, 2014 | General Electric Profile WPDH8800JMG 4.2...
Washing machine wont drain
Does the washer spin when in spin cycle ? If it does spin and there is no water coming out of the drain then you most likely have a bad wa
Aug 07, 2012 | GE Washing Machines
Displays PFE
The washer will stop during spinning .
Spinning is insufficient. Error display PFE
Is the filter of the drain pump clogged?
Is the drain pump operated?
Did you use the proper amount of detergent?
Is the drain hose placed higher than 1m above floor?
Mar 11, 2012 | Washing Machines
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
Does not drain and spin
It sounds as if you have a defective timer control. Try operating the washer on a different cycle, if it spins on these cycles the mechanical workings are fine it's an electrical switching problem in the timer.
Sep 17, 2009 | Malber WD1000 Front Load Washer/Dryer
New water pump, cleaned trap, checked little vaccuum hose and it wont do final spin. No errors on panel and everything else works fine
If your washer fills to the correct level, agitates through the wash cycle, and then drains, I would check the door safety switch for proper positioning and switching operation. The switch should have minimal resistance (closed circuit) when it is depressed and high resistance (open circuit) when released.
Jul 31, 2009 | Washing Machines
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
General Electric WCSR4170D Top Load Washer Logo
135 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
