Question about Golden Technologies Companion II Travel Scooter
Green light flashes 9 times will not go
Golden companion II When I press the speed lever I get nothing. the horn works the light works the battery shows 24 volts. the lever is ingage. the speed control is in the middle speed green light flashes 9 times
  • Anonymous Mar 15, 2014
    every thing lights up batteries fully charged when you grab the lever to go you can hear a clicking sound the service light flashes more then 8 times i separated it put it back together and still will not move I did a bell and battery test all the connections are good what should i look at next
  • 177 Answers
Hi. Different brands of controllers give different fault codes.If this is a dynamic controller, 9 flashes is the code for a faulty controller. This does not always mean that the controller is actually at fault.
It could be a burn't out brake solenoid, that now has a different resistance through the solenoid coil.
You mention the middle speed green light is flashing, normally on dynamic controllers, it is the most left battery level LED that flashes. You might have a different controller.
Have a look under the panels and let us know what controller your machine has.
You could try the agents, and see if they can tell you what the problem is.
Good luck. Neil.
Posted on Jun 06, 2010
My scooter will not start. The headlight and horn work.
HI,
I AM A GOLDEN TECHNOLOGIES REPAIR TECH.
SEVERAL THINGS CAN BE THE PROBLEM:
1. BATTERY CHARGER CAN BE BAD
2. THROTTLE POT OR SPEED POT CAN BE BAD
3.IF THE FREE WHEEL LEVER IS NOT ENGAGED THE SCOOTER WON'T RUN
4. IF THE CHARGER CORD IS PLUGGED IN IT WON'T RUN
5. FINALLY IF ALL THOSE ITEMS ARE OK YOU HAVE A CONTROLLER PROBLEM, WHICH IS THE MOST LIKLEY PROBLEM...THATS COSTLY
YOU CAN GET HELP BY LOGGING ON TO GOLDEN TECHNOLOGIES.COM AND ENTERING YOUR AREA CODE TO GET LOCAL PROVIDERS TO HELP YOU. OR CALLING 1-800-624-6374
GOOD LUCK
TIM
Apr 27, 2011 | Golden Technologies Companion II Travel...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
I have a Golden Companion II, all power comes on:light, battery meter and horn but it won't move when I press the throttle. I do hear the click from the brake but it won't move forward or reverse. If its...
Tony Check the freewheel lever Make sure that the scooter can't be pushed easily. If you can push it then its in freewheel. Now Tony you could have a problem with the brake itself. There is a small micro switch on the brake that engages and disengages when you move the freewheel lever. If you can get a close look at it make sure that it still looks like its operating its a mechanical mech activated by the lever on the brake. If it looks ok and you can get the scooter in or out of freewheeling (the rear wheels lock and unlock) then it could be a throttle pot problem or a speed control pot problem. Fortunately you can't bypass the throttle or speed pot. You will have to get these checked by a tech either with your provider or a service company that has techs around your area. I'm sorry I couldn't give you a quick fix but scooters are more difficult to troubleshoot because of all the different componets necessary to make it go. Good Luck Hope this helps
Oct 27, 2010 | Golden Technologies Companion II Travel...
Suspect the charger is shot on a seldom used like new Companion II. The batteries are at 3 volts but the charger red light wont illuminate when plugged in. Green light comes on, but not the red. I did see...
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Oct 03, 2010 | Golden Technologies Companion II Travel...
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
My Golden Companion II scooter had to be left out when it rained - I went camping - and it stopped running. Then, a little later, when it had thoroughly dried out, it ran sporadically. Now, it doesn't...
Hi. Most speed problems on scooters, can be the throttle pot ( wig wag ), or the motor brushes.
Also check all battery lead connectors, and the motor lead connectors.
While you are driving along, try moving the speed lever slightly up and down, not in and out as you normally do. If the speed changes, it is probably a faulty pot.
Do you have a high/low switch, or an indoor/outdoor switch that changes the speed? These sometimes cause speed changes. You can fit a new switch or by-pass the switch, and have it on high all the time.
Good luck. Neil.
Jun 15, 2010 | Golden Technologies Golden CompanioN II -...
I haVe two golden companion scooters that worked Perfectly. One day they just quit running. I know that when the light blinks a certain number of times in the manual it tells you what's wrong. Both of mine...
Hi. 5 flashes on some scooters is the fault code for brake coil open circuit. This usually means that the free-wheel lever is in the wrong position.
Someone might have moved the levers so that they could push the scooters, and forgot to put the levers back to the correct position.
This fault code can also mean that the solenoid coil is faulty, but 9 times out of 10, it is the lever in the wrong position.
Good luck. Neil.
Jun 12, 2010 | Golden Technologies Golden CompanioN II -...
Not moving and green light is flashing
this is batteries
if slowed down first then stopped
mobility centre penge
Apr 14, 2010 | Golden Technologies Companion II Travel...
Golden Technologies Companion II Travel Scooter Logo
585 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
