Question about Vitamix 5000 Work Top Blender
Our wet container smoked and smelled, the taste of plastic got in the shake..There is no "visible" trouble Do you think it could be just the agitator or do you think it could be the motor Model 5000
    President:
  • 2,702 Answers
First take off the container and on the under side bottom of it that sits in the unit is a drive gear see if you can turn it with your fingers also at the bottom of the wet container inside it is a blade that spins in a bearing and this bearing gets tight or even seized up at times strip out this bearing and renew it and the seal but watch your fingers as the blade is very sharp rap it in a thick rag to hold it in your fingers,,,,
Posted on Jun 06, 2010
  • StuartP Jun 02, 2011
    I did a DIY repair of my cease up blender jug bearings. My blog post about it is here.http://eatmoreraw.net/blog/?p=1003
Smoothie pro 600 manual
It means it's working very hard,
I suggest to put items that are thick in first and blend them then add the other ingredients after , the smell is the coating on the motor getting hot , if you see smoke coming out, drink your smoothie wash it out and take it back for a new one.
Jan 06, 2014 | Blenders
Vitamix smoke and smell
My bmw e46 320d have a thick white smoke smell like diesel when I start it. when reffing there is much more smoke. Model 2001/2002. What can the problem be
Jan 03, 2014 | Vitamix Blenders
Burning smell in the container and outside when in use
Seal under blade Assembly, on shaft leaks, allows liquid to enter bearing, which then fails, creates heat and overheats rubber, thus the smell. Bearing and seal must be replaced.
Jul 11, 2012 | Breville BBL600XL. 5-Speed Blender
The blade in my Super 5000 wet container turns very stiffly.Should I take it off and lubricate it? There also seems to be water visible under the bottom of the container.
Stiff or stuck blade problems can be fixed by replacing the two bearings and seal inside the blade assembly. Care must be taken in installing the new bearings as not to damage them. Ideally they should be pressed in, on a press, but they can carefully be tapped in using a sockets to match inner and outer races so your not tapping on the balls.
Mar 20, 2011 | Vitamix 5000 Work Top Blender
K-Tec Champ HP-3 Burning Smell and Light Smoke
That burning smell is kind of a death sentence. At least a switch or more likely coils are burnt out.
Mar 27, 2010 | K-Tec Champ HP3 Work Top Blender
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
May 09, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
My Sunbeam Kitchen Assist doesn't work
Hi there, you might want to check the swithing mechanism that turns the motor ON. I don't think the motor will fail, specially if it doesn't smell like it's burnt.
Just an idea...
Chino
Feb 26, 2009 | Sunbeam 2774 Blender
Vitamix 5000 Work Top Blender Logo
1,536 people viewed this question
Top Vitamix Blenders Experts
Holly...
Holly...
ray gallant
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
