Question about Magic Chef 24 in. DC4000 Free-standing Dishwasher
New dishwasher will not drain at the end of the cycle
My new dishwasher will not drain at the end of the cycle
  • Magic Chef Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
Dishwashernew dishwasher will not drain at the end of the cy - 2_bing.gif Trouble No Water entering Dishwasher2_bing.gif
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Jun 07, 2010
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
Our dishwasher will not drian out all the way. I cleaned out the screen and sump and it still does not drain out all the way. I also ran the unit and waited for the drain cycle and it seemed to flow...
hi Richardcr1.
After having examined many dishwashers that were replaced because they wouldn't drain, the largest percentage of them were simply because of a clogged drain hose or pump strainer. Too many people seem to think that the dishwasher is first cousin to a garbage disposal. It is not.30 Apr 2010
SOLVED: Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/Answers/View/.../Does+not+drain+the+water+at+the+end+of+cycl...
How do I fix my dishwasher that will not drain?Check for a clog:Make sure the kitchen sink drain is not clogged.If a disposer is installed, run the disposer to clear the drain system. Do not put hands into the garbage disposer. ...If an air gap is installed, remove the cap and remove any debris. ...Do not use drain cleaner in the dishwasher.Dishwasher Does Not Drain - Products - GE Appliancesproducts.geappliances.com/appliance/gea-support-search-content?contentId=16240Search for: How do I fix my dishwasher that will not drain?
Nov 29, 2017 | General Electric Dishwashers
The dishwasher will not drain.
Check your main drain system. Remove the drain hose from that end and discharge them in a bucket. Try a new wash an if the m/c drain system is ok, it will discharge water in the bucket.
Check the house main drain for clogging at the hose connecting end.
May 25, 2010 | Bosch SHU5315UC Dishwasher
Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Feb 02, 2009 | Haier ESD300 / ESD301 Built-in Dishwasher
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
132 people viewed this question
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
