Question about Gaggia Baby Espresso Machine
Water coming through very slowly and not making any crema (Baby gaggia Espresso maker) Have already taken the shower head off and scrubbed it.
    President:
  • 2,702 Answers
Get some kettel cleaner mix it up in warm water and run it through the espresso maker a good fuw times catching it in a jug so you can run it through again to clean it out its just cloged up with scale,,after you have given it a realy good clean through and its flowing right run cold clean water through it till all traces of kettel clean has been flushed out
this should be done often???
Posted on Jun 06, 2010
Weak coffee/water flows too fast
you need to take it to a service center as it is still under warranty they should be able to get it fixed for you
Jan 25, 2014 | Gaggia Baby Espresso Machine
Have a baby gaggia coffee machine and unable to find anywhere that will service or repair. The machine has worked really well for 3 years but now is making aloud noise when working and the flow is very...
The loud noise is coming from the vibrating water pump.
One posibility is that is full of scale or and dirt so you can try descale the machine.
Second is probably the water tank can fit corectly on the base and the valve on it does not open correctly or not at all so the pump it can not s**k water but air or a mix of them so we have the loud noise.
Finally you can remove the shower disk on the group head , locate above where you place the filter holder and clean it probably is full of dry coffee and block the water way out.
Please note that can be all above problem together.
Good luck
Mar 27, 2010 | Gaggia Baby Espresso Machine
How to remove shower disc
You can use the filter holder blocked with a piece of nylon so water will make the coffee around the shower and screw to desolve. Just keep the filter holder with hot water for 30 min and then try to remove the screw. You can hold the small screwdriver with a plyer and by heating it a litle bit on the back try at the same time to turn it. This will loose the screw.
Dec 20, 2009 | Gaggia Classic Espresso Machine
No water coming thru machine head
Remove the shower screen and screw then try if water flows clean shower, if not remove diffuser screws and check spring and valve to make sure it is not blocked.
Dec 14, 2009 | Gaggia Classic Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine - water comes out of steam wand but not group head. tried priming, cleaning
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Oct 21, 2009 | Gaggia Baby Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
No water coming through - New Gaggia Baby Dose
Try this remove the portafilter, then press the button for brewing coffee and then turn on the machine, if both hoses are in the water reservoir, then water should flow out of the head after a few seconds.
Jul 20, 2009 | Gaggia Baby Espresso Machine
No water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Jun 18, 2009 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
435 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
