Have a Kenmore Elite top loading machine and the water starts to fill the drum and it empties out as it fills, so the drum only fills half way. No agitation or spin. Because it just sits there with the water coming in and emptying.
    President:
  • 2,702 Answers
This sounds like the fill up censer is blocked up,,,its a cheep fix,,, its only a pipe that fills with water and at a set point it stops filling the washer, but if the pipe is partly blocked it throws its self into a wobely?? and thinks its over full so it starts to drain this water out
a good pear of lungs should blow any muck out this pipe
Posted on Jun 06, 2010
I have a kenmore series 80 washering machine. The washer begins the wash cycle mormal. About half-way through the wish cycle the washer begins to fill with water again. It will fill with water until to...
the water level control has gone bad,its located in the top of the washer control panel,four philips head screws gets you in there,make sure you unplug the machine,it has a rubber hose,and four clip on wires,one 1/4 inch screw holds it in place,its job is,it works off of air pressure from the rubber hose that comes from the washer drum,if it don"t read the back pressure from the drum being filled it will over flow.good luck
Nov 19, 2012 | Kenmore 24032\24036 Top Load Washer
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he3t drum filling on its own
replace fill valve under top rear left easy fix dont wait it call flood your house
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
Drum filling with water after cycle is done
replace bad fill valve its bleeding throw under top left rear easy
Water in Drum
replace fill valve under top left rear its bleeding throw it will fix that
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
