Question about Master Lock 5400d: Portable Select Access Key Storage Lock
Reset the combination on my Master Lock 5400D while on door.
A rental guest reset the combination on my Master Lock 5400D. Is there any way to figure out the new combination? The guest doesn't have a clue and the lock is attached to our door.
  • 10,515 Answers
I am sorry to hear regarding the Problem. They need to contact Master Lock.That would be the Only solution,if they don't remember the combination.
Procedure :-
http://www.masterlock.com/faq/lostcombo.shtml
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 06, 2010
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
Lock open can't reset the combo because reset lever won't move
Hi, Try setting the lock to the original combination and see if it will move then. Also keep a can of spray lube handy (and a rag) to give it a good squirt and free up any rust inside. Good luck.
Nov 16, 2010 | Master Lock 5400d: Portable Select Access...
I have a 5400D Master lock.I changed the default combanation and hung it on my closet door and approx. two months later it remains there because I forgot the combo.I called Master Lock and was told its...
Master Lock would be thrilled to sell you a new lock. Run through the possible combinations, systematically, until you hit on the correct one. There are 10,000 of them. Shouldn't take any longer than a week.
Oct 26, 2010 | Master Lock 5400d: Portable Select Access...
My friends were messing around with my 1500ID lock and changed the combination, then closed it. How can I reset it and change the combination?
Make your dumb friends find the code or buy you a new lock.
there is not trick to it... it'll have to be done by trial and error...
Sorry for your troubles.
Aug 31, 2010 | Master Lock 5400d: Portable Select Access...
Master Lock 5400D Key Storage Combination Lock box i reset it combination a couple of days ago and it worked fine until today. Now it won't open with the new combination. How can I get in to it without...
Two solutions: (if the box is closed and it is attached to something)
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Jun 25, 2010 | Master Lock 5400d: Portable Select Access...
Problem with Master Lock 5400
You have 10,000 combinations to go through. Best to cut if off and bring it some place comfortable to try out all of the combinations from 0000 to 9999. Or take it to a machine ship and have someone grind the thing open.
Aug 09, 2008 | Master Lock 5400d: Portable Select Access...
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
factory to 0-0-0-0
(see instructions above)
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Lock won't open
Have 5400D Master Lock. Know combination, but it will not open. Can someone help me?
Aug 18, 2007 | Master Lock 5400d: Portable Select Access...
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
636 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
