Question about Western Digital My Book (WDG1U2500) (G1U2500N) 250 GB Hard Drive
Hi; I have a WD mybook essential edition usb 2.0, 250 gb mybook. Recently we moved a lot of furniture, including all my computer. I have several power cords, and I don't know which one goes to the Mybook external drive. Is there any chance you can send me a picture of the correct power cord, or tell me what is written on it ??? I don't have one that says WD or any other identity name or number. My unit has a serial number of WD25001032-001. Thanbk you for any help you can supply. john hathaway jh48burn@aol.com
Benimur
  • 6966 Answers
SOURCE: mybook essential edition
Hi, As I have responded to a similar post, this is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the WD500GB itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Posted on Sep 03, 2007
SOURCE: Mybook essential
Hi guys...
I had kind of the same problem like u...when i plugged it into the usb all i got was a "unknown usb device found"
I opened the external case hoping the hdd was still ok only to find out that the hdd cables had been moved slightly out of position..propably from a fall or a knock I didn't even noticed..
I just pressed them back in..click..and everything was back to normal..
These sites have info about how to open the external case..
http://rebootdaily.blogspot.com/2007/03/how-to-open-western-digital-my-book.html
http://anotherdeadblog.blogspot.com/2007/09/how-to-open-western-digital-my-book.html
Hope that helps!
Posted on Dec 10, 2007
SOURCE: hi i have a WD
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Posted on Dec 15, 2008
bunnydawg
  • 5158 Answers
SOURCE: Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Posted on Jan 05, 2009
  • 523 Answers
SOURCE: Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
Posted on Mar 09, 2009
Change mybook from one pc to another
You have to install the backup software on the new computer. Either download from WD to use what came with the MyBook. Attach the MyBook and find it in My Computer. If it is not there, you have to reboot and find the attached device. After Windows recognized the drive, the backup software will ask you for a new backup but just decline and reactivate the plan (actions/reactivate). That should do it!
Dec 05, 2011 | Western Digital My Book Essential Edition...
Notebook does not recognize My Book / Western Digital hard drive
Did it ever work?
Connect the MyBook to a different desktop computer.
If it is not recognized, then the MyBook definitely has a problem.
Exercise the warranty to get it repaired/replaced,
or check W.D.'s "Customer Loyalty" program -- buy a new W.D. drive through W.D.'s web-site, and get a discount.
Nov 01, 2010 | Western Digital My Book Essential Edition...
Connected but not detected?
Hi, You need to run updates for your computer. Go to start, program, windows update, run and install all the updates, look especially for any update for hardware, select it and let it install. Leave the My book attached to the computer while searching for updates. Good luck.
Dec 21, 2009 | Western Digital My Book Essential Edition...
My WD 250 GB ext. HDD, not showing data, but showing free space
files are there but data is not there & its showing file is empty
Feb 18, 2009 | Western Digital My Book Essential Edition...
Jan 05, 2009 | Western Digital My Book Essential Edition...
Connection problems with my Western Digital MyBook EE 2.0 320 GB.
Go to Programs and Devices and see if your Western Digital MyBook is even listed on your computer.
Jun 28, 2017 | Western Digital My Book Essential Edition...
HOW TO CHANGE 320GB SATA HDD TO 500GB SATA
Yes. The case doesn't care what size the drive is. The computer is just asking for the USB driver for the case. Check the WD site for the driver for the model of MyBook that you have. That should cover it.
Dec 23, 2008 | Western Digital My Book Essential Edition...
Hi i have a WD mybook both the lights on the power cord and the device itself are flashing rapidly and i am unable to acess the external drive. i have tried using a different computer, tried a different...
Thanks
Dec 11, 2008 | Western Digital My Book Essential Edition...
WD My Book Essential -- Can't find drivers
It should not really need drivers in Win2K or Vista, you might have a problem with your USB drivers. Go into device manager, remove any devices under the USB heading and reboot. All the drivers should reinstall and hopefully your MyBook will come alive again. Otherwise, try the MyBook on a friend's computer, if it doesn't work there then the MyBook may be faulty itself.
Jan 15, 2008 | Western Digital My Book Essential Edition...
Problem with accessing wd mybook 500
Hi Bella. I just recently had the same problem with my 160GB essential and I found a forum that helped me. The guy said start your computer fully with nothing plugged into your hard drive but the usb plug. Then, after windows has completely loaded, plug your power into the drive. It worked for me like a charm. I hope it does the same for you.
Oct 08, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book (WDG1U2500) (G1U2500N) 250 GB Hard Drive Logo
216 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
