Question about LG 42PC5DC 42 in. Plasma HDTV
How to disengage the stand from an LG 42PC5D
Trying to wall mount the TV but cannot figure out how to disengage the stand
When I tried to do the same I took the same approach but could not pull the stand - is there another safety pin or something like that?
I took out two screws from the back that had been holding the metal top of the stand inside the panel - but when I try to lift panel off it does not move!
Posted on Aug 14, 2010
  • 91 Answers
There are two pegs that protrude from the base into the tv.......there will be two large philips screws on each. remove and pull strait up off the base........hope this helps!
Posted on Jun 06, 2010
4 Suggested Answers
SOURCE: I am trying to wall mount my LG M197WDP - PZ 19
It's simple!
Step 1: Use a Phillips screwdriver to remove the screws holding the red plate off the bottom.
Step 2: Pop the red plate off (May need some persuasion! It should pop straight out, there is nothing else holding it in place, but be careful)
Step 3: Unscrew the four screws holding the spigot in place, and remove the spigot.
Step 4: Screw the 4 screws bach in place.
Step 5: Screw the red plate back into place.
Step 6: Enjoy!
Posted on Jan 08, 2010
Select TRNX
  • 4 Answers
SOURCE: wall mounting the LG 42LC2D TV there are holes in
There will be 4 big holes used to install a mounting bracket on the back of the TV.
Posted on Jan 10, 2010
  • 3 Answers
SOURCE: my lg 42pc5d tv remote sensor quit working. I am
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
Posted on Mar 25, 2012
Set up for lg cs570
Some stands come with a mount that looks like a wall mount, ready to mount to the TV. If not then use the table top stand that came with the TV
Jan 02, 2014 | LG 42" Cs570 Series Black Flat Panel Lcd...
I mounted my tv on the wall by screwing it to a piece of wood than to wall, now i have moved and no longer have a stand for it. i am trying to figure out how to build a stand because i cant afford a new...
You can always buy a wall bracket for fixing TV from your Brand retailer OR any other electronic shop. OR Contact Brand service center in your town.
Jan 27, 2011 | Televison & Video
I am trying to mount my LG 37" on the wall and cannot figure out how to remove the stand that came with the tv
37LG30 - loosened the 4 screws on the back of the TV but base mount wouldn't come off. Found that had to remove the screws even though already loose so that doesn't bind in the holes. Did this by making the loose screws bind in the wholes. Using twisers in the whole would have done the same thing. o
Dec 27, 2009 | LG 37LG30 37 in. LCD HDTV
Trying to set up hdtv antenna - have lg 42pc5d
cable got installed but i cant make it work
Apr 29, 2009 | LG 42PC5D Television
Lg lcd tv screen goes black but the sound still works 52lg70 screen goes blank, sound still works. i can change settings but cannot see the menu so the tv is still working there is just no picture.
This sounds like a mainboard problem. Unless you do not see a back light flash when you turn on the TV, which may mean it is an inverter board problem, this is most likely fixable by replacing the mainboard.
Jan 20, 2009 | LG 52LG70 52 in. LCD HDTV
Cannot remove the stand on the 26 inch LCD tv (soyo)
Hello you remove the last four screws on the back of the tv located down at the bottom theres two on each side the stand will slide out...
Jan 04, 2009 | Soyo DYLT032D 32 in. LCD Television
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Dec 02, 2008 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Remove stand from LG 50PC5D
There are four screws in the back of the TV above where the stand is. Inbetween the screws is a metal handle that pulls out. These four screws need to be removed and the metal handle pulled out. Then the TV will come off the stand.974336c.png
Oct 16, 2007 | Televison & Video
LG 42PC5DC 42 in. Plasma HDTV Logo
484 people viewed this question
Computer Repairing
Computer Repairing
