Question about Black & Decker CCS818 Chain Saw
Blade wont move
Chainsaw sounds ok motor ok but blade wont move will the problem be because there is no oil in it.it is a electric chainsaw
  • 86 Answers
There is a broken gear in the gear reduction box. (explain:) the motor spins at a high rpm, the chain moves at a 1/4 or less rpm than the motor. a series of gears reduces the speed, which in turn creates torque, allowing the saw to have the force to keep cutting without stopping. One of the gears is broken or a keyway on a shaft is sheared...as far as i know, no electrical power tools are rebuildable. it's a safety thing (electric shock if reassembled wrong...they are priced for replacement...get a new one...
Posted on Jun 06, 2010
Motor buzzes, fan does not move, blade does not move, blade is clear of obstruction
Removing blade will not do it - there has to be an obstruction in the drive mechanism that prevents it from turning. Leave off till fixed lest you risk burning out the motor completely. Turn on AFTER you can turn the blade freely.
Sep 03, 2017 | Remington 3-Amp 17" Extended Reach...
I have an Remington 3.25 (Peak Hp) 16"/40, 6 cm electric chain saw, And I have just a few questions 1.) Does it take oil/gas or just oil and if so what kind. 2.) How would I tighten the chain, its...
It uses oil only to lubricate the chain. The type of oil in not critical although special chain saw oil is available. If you use anything but chain saw blade oil, make sure that it is a light oil, both in viscosity and in colour because it is a total loss system and dark or dirty oil can become very messy. The chain adjustment is on the body at the end of the blade, it actually moves the blade in or out to set the chain tension. The chain should be tensioned that when it is pulled at the bottom, the guides of the chain should not quite come out of the slot in the blade. If the chain is too tight it overheats the blade and stretches the chain.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
It wont clip. sounds like it is working but the blade wont move. thanks
Open and clean the blades well use some light oil to clean . it is possible that the cut hair had entangled into the moving parts and joints. You must always clean the blades with the given brush after the shaving is done. If the blades are not moving then the gear drive from the motor is defective or worn out. you will need to open out the assmebly to confirm on thisbut replcement will be difficult. Hope you try. Good day
Aug 14, 2010 | Health & Beauty
What lubricant oil is used on the blade of a Wen electric chain saw?
I have a Wen 2000 10" electric chainsaw and just ordered a new chain, , but does it need oil poured inside? I have no manual. what kind and how much? can it be over filled, there is a black screw off knob that appears to be for oil?????thanks Kim
Apr 02, 2010 | Electric Chainsaw Sharpener
Just got MCC4516F chainsaw.Used it for 30 mins. Stopped working. Chain brake does not engage or release. Chain does not move. Motor runs but will not engage to make blade move. Seems like chain brake...
You have obviously jammed or broken the chain on the inside of the motor. Take it to be repaired, or try reparing yourself by opening up the engine casing yourself.
Nov 19, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
My McCulloch Electric Chainsaw model 450s_15 runs for a few minutes then quits. Does this saw have some type of thermal protector? If not is there any idea what may be causing this malfunction
Remove the bar and chain. Does the motor run and not quit? If not, inspect the motor for sawdust plugging the vents and check the brushes for condition and length. If runs ok, check the side port for oil coming out. If ok, clean all of the holes in the drive end of the bar including the two small holes that pass oil to the chain slot. Use compressed air if available. Also, clean the chain slot all around. Oil the sprocket tip if the bar has one. Adjust the chain so that it moves freely, but doesn't droop from the bar.
Aug 06, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Motor runs, but blades dont move
with engine off, take a screw driver and manually move the blades to make sure that they are not jammed. Then spray the blades down with wd-40 oil and they should move freely again.
Jul 28, 2009 | Garden
Motor runs but blade does not move. Sounds like gear stripped or maybe clutch slipping.
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Jul 17, 2009 | Remington 111409 - 01 6" Branch Wizard...
Poulan 18" Chainsaw - Motor runs fine but blade stopped spinning
Chain may be locked in the bar. Caused by low oil flow to chain. You will probably have to remove the bar and blade. Then try to rotate the sprocket, if it will not rotate you may have to replace or repair the clutch. with the blade off try starting the saw and see if it is oiling. There is a small hole in housing that oil should be visible coming out at a fairly good rate. If not you will either have to open orifice in the housing or repairing the oil pump.
Apr 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Mcculloch chainsaw 2014 Eager ****** Model 00032-14
a fix that sometimes works is to add kerosene to oil tank where the oil would go normally and rev saw several times with out load holding blade in down position over a piece of dry card board so you can see the oil spraying on the piece of cardboard careful of moving chain
Jan 02, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Black & Decker CCS818 Chain Saw Logo
242 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
