Question about Sony Handycam DCR-DVD108 DVD Camcorder
Sony HI8 HandyCam is flashing a yellow symbol at me
It will not work and there is a line with a little triangle symbol. The timer is flashing C:31:23
  • 31 Answers
SOURCE: sony 700x digital handycam
error 31 is some kind of a problem with the cassette compartment, it's either won't eject it right now, or it's stuck otherwise. try to eject, if doesn't work, try "reset" button, if still no luck, replace the cassette compartment
Posted on Aug 21, 2007
SOURCE: c-31:21 code eror
Take the Tape out
Leave the cover open.
Take the battery out.
Leave this for about any hour or so. The rollers inside has moist. Alternatively use a hair dryer but not to close.
This will work
Posted on Nov 07, 2007
SOURCE: Video camera displaying Error code C:31:23
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
Posted on Aug 03, 2008
SOURCE: video transfer from sony handycam ccd-trv 308 hi8 to a computer
I have a sony handycam ccd-trv 308 hi8 analog camcorder and I was trying to transfer videos from it to my computer. However, when I plug the S-video cable to the handycam and my computer, nothing happens. Does my computer require a driver to recognize the handycam because I cannot find any in the sites of sony for my handycam's model. Or am I using the wrong wire?
Posted on Oct 09, 2008
welcomejee
  • 10594 Answers
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Posted on Feb 26, 2009
Handycam Hi8 CCD-TRV81: There is a cassette in cam. Will no play, or FF, or reverse. Eject arrow flashing, but will not eject/open
Before i proceed, do you see any flashing triangle in the viewfinder?Any error message?
Thanks!!
Aug 25, 2010 | Sony Hi8 CCD-TRV138 Camcorder
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Will not play on new RCA LCD TV tried different
Try hooking up your sony handycam to a different monitor or tv to make sure it is putting out a good video signal using an S-Video cable. Then once you know your cords are good and you have a good video signal, hook it back up to the RCA LCD unit. If it is still not working make sure that the RCA LCD is set to receive the Hi8 signal via the S-Video cable. There may be a switch or menu setting on your RCA LCD to accept the Hi8 signal or also refered to as S- Video.
I hoped that helped and good luck!
Nov 16, 2009 | Sony Handycam CCD-TRV68 Camcorder
Get video off Sony Handycam DCR-TRV118 Hi8 to PC or Mac
Hi There,
MisterSony is quite correct about the Capture card.
While most computers have the built-in ability to capture sound via the 'Line In' port, digitally recording the Video signal is a totally different aspect.
Certain TV Tuner cards also have Video Capture abilities (in addition to the tuner they have a VCR input). They often work in tandem with your Video Display card via the 'Feature' connector.
Both types allow the incoming signal to be displayed and recorded digitally at your choice of speeds, resolutions and formats.
My preferences in the past have been the VideoBlaster line by Creative Labs. There are many others.
I'll do a little research as to what's currently out there and post my findings directly.
Mike
Nov 01, 2008 | Sony Handycam DCR-TRV118 Camcorder
Hi8 Playback Problem
Clean the tape heads and see if that makes a difference.  If that doesn't work, it could be the tape motor is going out.  Thats typical behavior when that happens.
Oct 07, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Movie recording disabled
When I try and record is just keeps saying movie recording disabled, it also flashes a yellow symbol
Aug 10, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Icon
The icon you see is "EJECT" tape. It shows there is a problem with unit but cannot be defined without having unit checked by a pro tech
Apr 06, 2008 | Sony Handycam CCD-TRV37 Camcorder
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
411 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
