Question about Frigidaire FDE216RE Dryer
Will not start, check the start button and it is good What should I check next?
  • 429 Answers
No laughing now, wife did it to me yesterday fixing a blown breaker for the A/C
Check the breaker, and I would then check the plug to make sure the prongs are good.
Next you are looking for the saftey switch on the door.
Then I would look at the timer.
Posted on Jun 07, 2010
Push start button and nothing happens. Whirlpool #WTW4800XQ. Checked all connections.
1st off, you said all connections, but are you sure outlet is good? If so, I would next get a new panel for the start button. Sounds to me like a loose wire or shorted out.....
May 08, 2017 | Whirlpool Dryers
Atv repairs
Hi Lee,
The starter requires substantially more current (amps) than the little wires and contacts that make up the start button and starter circuit. These small wires power a solenoid (an electro-magnetic switch) when the start button is pressed; which in turn closes a much larger contact that connects the larger battery wires to the starter motor.
You may have a blown fuse or fusible link, bad starter switch button, bad solenoid, broken wire(s) between the starter button and solenoid, poor connections at any of the terminals on these devices or a bad starter motor. Check the these circuits with a volt meter capable of testing 12 VDC or using a test lamp. Start with the one probe of the meter or lamp connected to a good ground or (-) post of the battery. The other probe should see 12 V (+) power on ONE of the starter button wires and on BOTH when the button is pressed. If not, work your way back to a bad connection or cut wire. Next, locate the solenoid. There should be two heavy cables and one or two smaller wires entering. The smaller wire is from the start button. Power 12V + should be on it when the button is pressed. If there are two smaller wires, one is probably ground or (-). If no power, check the wire for damage, etc. by following the wire back to the starter button. Once you have 12 V + starter circuit working into the solenoid, go to the next step.
Next, check the two heavy cables on the solenoid. One should have 12 V + power on it all the time and the other should have power only when the starter button is pressed. If you do not have power on one of the cables all the time, there is a bad connection,etc. between the solenoid and the + battery post. Check fuses, connections, etc. and make repairs. With power on one cable, press the start button A working 12 V starter circuit is required for this to work. If no power on the other heavy cable, the solenoid should probably be replaced. If you do have power out, it it still won't crank - check the cable between the starter and solenoid. Repair or replace as needed. If cable is good, the problem is likely to be the starter itself.
Apr 01, 2014 | ATVs
2006 yamaha bruin will not start by push button. Battery is fine, all lights come on but when button is pushed nothing happens
Hi. Depending on your skill level the starting point would be check "ALL" the fuses with a test light/multimeter. Next point would probably be check the starter itself, Again with a test light or multimeter you should have the main positive to the starter - make sure you have good battery voltage and check this whilst attempting to crank. Then the crank feed itself which is the small wire to the starter solenoid, Again check for good voltage whilst attempting to crank. If there is voltage on both then make sure the starter has a good earth by using the starter motor body as the earth whilst testing the main feed at the starter. If you have good main feed and crank the starter has failed. If not you need to post your test results for further help, Jon
Dec 09, 2013 | Yamaha 2006 Bruin 350 Auto 4x4
When you press the start button nothing happens. I checked the door switch, and the start button switch, and it is getting juice.
may have a bad thermal cutoff fuse usually located next to exhaust inside unit....remove panel and gain access.. it will usually be white in color and plastic with 2 terminals coming off of it...take a meter and ohm it out should be closed if good and opened if bad.... anymore questions repost....good luck
Jan 09, 2011 | Roper REX4634KQ Electric Dryer
Does nothing when you press start button. Have checked the door switch, the start switch, the plug, the cord all with ohmmeter and they are all fine. Circuit breaker is good. I am at a loss. Wife had...
This is a simple dryer. the thermal fuse is mounted on the heating element. Clear any air restrictions that would cause dryer overheating before replacing that fuse. If the fuse is good then the door switch is the next most likely place to lookthemobilian_375.jpg
Manual and more here
Dec 06, 2010 | Amana NDE2330AY Electric Dryer
My suzuki katana 750 will not start and there is a new charged battery in it. Why will it not start? The electric starter button does nothing, other than dim the lights. I checked the fuses and they seem...
It sounds like your battery is no good. have it load tested a good battery under a load shouldn't drop below 11 volts. if you starter button is only dimming the light it is a good guess that your getting power to the swtich and the starter motor but the battery dosen't have a juice to turn the motor.
good luck
Mark
C.C. Motorsports
Feb 22, 2010 | 2006 Suzuki GSX 750 F (Katana)
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
My dryer will not start. It is only 4 yrs old.
Check your power source to make sure you are getting the proper voltage. If so check the electrical power connection on the back of the dryer where the cord is connected. Make sure the connections are tight. MAKE SURE TO DISCONNECT THE POWER FIRST. If all of the above are in good condition the the start button would be the next area to check whithout the proper electrical meters this would be hard. however, the next item in line to prevent the dryer from working would be the start button or the door closer switch. Both of these need to be checked using an electrical meter. If you have an apliance tech check it for you it shouldn't be expensive at least you hav an idea as to what is wrong.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
2000 Explorer cranks over good but just will not start.
Try spraying with starting fluid. If it starts, it is your fuel pump that is not working. Good luck.
Jan 08, 2010 | 2000 Ford Explorer
Dryers Logo
44 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
