My plasma tv switching off byself
Is a very annoying problem, just started recently.In certain time without any reason- is switching off by self.When the monitor goes dark-switches off, the power light blinks 3 or4 times and after become steady red. Sometime can be switched back, with picture, sometimes not at all.Any idea?
  • 3 more comments
  • Gina1955 Apr 10, 2008
    We did try, but still switches off. So sill have got the problem. Thanks anyway...
  • JVRILEY May 16, 2008
    TURNS ON BY ITSELF
  • jonnysgirl May 20, 2008
    my 32flatscreen you will be watching it for a while and it turns self off then back on sometimes turns self on and not back on just bought this on saturday for 711.00 and brought it home and it was doing that right from the start.
  • vicbarrick Aug 23, 2008
    I have a 42 in. philips lcd. My problem is it shuts off by itself then after about 15 seconds turns itself back on. Green light stays on when this happens. No blinking red light. We seem to notice it happening more when we are using the comcast hd cable box tv guide. When we use the guide it shuts itself off and then back on repeatedly until we get out of guide mode.
  • Anonymous Mar 18, 2014
    tedelex tv switches itself off 40" plasma sometimes will work without problems and then some day just switches off after 30min
Sounds to me like your internal cooling fans are not working. Try placing a fan behind your tv and seeing if it stays on longer. If it does then you'll know it's a problem with these fans. Not expensive to fix but not easy to do either.
Posted on Apr 10, 2008
I have a LG 50PG60UD - AA television that appears to be overheating. TV starts up ok and keeps working without any major issues. A couple of times recently I have unintentionally switched it off and when...
This isn't an easy fix, it sounds like your power supply board is bad or there is a main board problem. I'd suspect a faulty power supply capacitor or heatsink missing, but you have to bring it in to a tech to know for sure.
Apr 10, 2014 | LG 50PG60UD 50 in. HD-Ready Plasma TV
I have a PDP-r06xe conected to a plasma, when i switch it on, it switch off byself and the blue led blink eight times. what can be the problem???
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hoping this will help solve the problem of the television.....
Jun 23, 2011 | Pioneer PDP-4350HD 43 in. Plasma...
When i turn my tv it goes on and off for 10-20 seconds until it turns on,started couple of weeks ago and it's getting worse. is it a Bad power switch circuit. can i replace my self?
Sounds like, and no it usually take a professional to replace. Trust me there tiny parts in there. Some tv's takes speacial tools to take apart without damage them.
Oct 22, 2009 | LG 42PC1D 42 in. Plasma Television
Z sus board fault
When ever either the Z or the Y main goes out, all of us service co's replace the Y main, Y up/lower drive boards and the Z at the same time. Now you will have to start all over. I just had a Samsung 50" that required all 4. It is a must with Plasma sets. Hope this helps.
Aug 25, 2009 | Televison & Video
Sound working no picture
Depending on the events leading up to what happend...
Was your plasma tv recently transported or moved from one area to another?
One thing about plasma tv's if you lay them horizontally or has been tilt at a certain angle they will have problems projecting any picture. PLASMA tv's should ALWAYS stay vertically standing. you can let it stand where it should be for atleast 24 hours ( i recommend upto 48 hours) without plugging it in.. (no electricity what so ever) then check if it works.
About the click you heard, it might have been a blown fuse. Probably resulting from plugging in the tv while it was in a "chemical inbalance". therefore my above recommendation is a bit too late. if you still have warranty then you have no problem. just the hassle.
Mar 01, 2009 | LG 42LC2D 42 in. LCD HDTV
Philips 42PF7320A cropping issue
Pete,
When using a hd connection on a philips tv and (I am assuming this is the case) the tv disables the format features on the tv and only lets you select widescreen and automatic, if you are using hd adjust the picture size from the cable/satellite box, look for it in the box's menu system or on the remote, it is usually labeled, aspect ratio, zoom, format or something to that nature, hope I helped you
Aug 20, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Samsung HD tv help
Is it a Plasma Television? I recently had a customer have the same issue with a 2 year old model Samsung 50" plasma TV. In his case one Of the computer panels failed. He didn't have a service plan and the warrenty was out, so i directed him to Samsungs help line. They inturn directed him to a authorized repair center. Repairs were roughly $800. Thats a possibility but it may not be the same as your issue. Try leaving your TV running for a little while when it has the issue, and see if it eventually goes away. Some older plasma models have started to require a warm up time for the pixel cells. This has been a down fall of plasma that for the most part no longer exists on newer models.
I hope eveything works out.
Have a great day
Mar 22, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
42 inch plasma
TURN OFF THE MAINS AND THEN SWITCH IT BACK ON
Jun 06, 2007 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
672 people viewed this question
Top Televison & Video Experts
Electro Med Services...
