Question about Patton U2-1487 Floor / Box Fan
Fan overheats My fan, a floor model P-205 Patton gets too hot then shuts down until it cools off. It's a tall one with a pole and circular stand. 120V, 2.7Amps, UL listed 686A. It runs for awhile on low, but shuts of fast on medium or high. Any ideas? Thanks.
4 Suggested Answers
issy2
  • 462 Answers
SOURCE: Blade for Patton Stand Fan Model 1010-MP1
does it have a slight bend or a worst one.. generally these blades are quiet to replace... please tell us where u stay...
Posted on Sep 09, 2008
  • 57 Answers
SOURCE: Any idea where I can get replacement metal fan
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
Posted on Jun 10, 2010
  • 8 Answers
SOURCE: where do i find a replacement motor for my patton
Before you replace it, try oiling it -- look at the little oil hole on the back of the motor housing. Or try taking it apart and cleaning it, then oiling.
Did it work before, but gradually slowed down and then refused to start? See other threads on this topic for that fan model.
Posted on Sep 07, 2010
1999 cadillac false overheat
bad temp sensor or wiring harness issue.
Dec 31, 2017 | 1999 Cadillac DeVille
u can get a replace blade from hard wares and fan shops also try ebay and oztion
Sep 09, 2008 | Patton (HASF1016UC) Stand (Pedestal) Fan
What might be the cause when machine gets hot when shut down
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 24, 2012 | HP G62144DX Laptop
Shutdown computer don't open again then 2/4 hours computer start then open.
Not exactly sure what you mean, but sounds like it could be a laptop getting too hot. Because the space inside them is so small, laptops overheat and shut down to protect themselves from damage. They will not switch on again for a while, until they have cooled down enough. One solution is you can buy a small stand to put the laptop on, which has a fan powered by USB. Try to keep the laptop cool and make sure the fans are not blocked by anything.
Jul 26, 2011 | Acer TravelMate 4740
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
My gateway mx laptop gets so hot you can fry an egg on it and the fan runs all the time and shuts down when its hit its hottest what can be done about this i have to shut it off or the fan will still...
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Mar 26, 2011 | Gateway Computers & Internet
My dv9000 locks up after it gets hot. What can I do?
A laptop locks up or shuts down when it get very hot. The CPU shuts down (thermal overload) when it overheats and will not boot up until it has cooled down. If this problem is not fixed, eventually the CPU will fail.
This problem could be caused be a faulty CPU fan and/or the CPU and heat sink assemble is clogged with dust.
Check the CPU fan to see if the fan blade spins freely (it may have a seized bearing), if not replace the fan. If the fan and heatsink is clogged with dust, clean and remove the dust.
If additional cooling is required and there are ventilation grills on the bottom of the laptop, then purchase a laptop cooling pad. Place the laptop on the cooling pad, these pads have fans that direct air into the grills at the bottom of the laptop.
Jul 21, 2010 | HP Pavilion dv9000z Notebook
Any idea where I can get replacement metal fan blades for a Patton floor fan?
Jun 08, 2010 | Patton U2-1487 Floor / Box Fan
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Patton U2-1487 Floor / Box Fan Logo
71 people viewed this question
Top Patton Dryers Experts
Mohamed Ismail
Mohamed Ismail
Are you a Patton Dryer Expert? Answer questions, earn points and help others
