Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Water dispenser leaking behind filler tube when filling glass from water dispenser. Can't tell if the tube is leaking above, or what the problem is
    Scholar:
  • 56 Answers
This may not be the problem now but by the sound of the malfunctioning ice maker, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
What causes leak between filter and filter housing on kenmore elite model 40141003010.
Hello Emile;
My name is Peter. I am a retired field service refrigeration technician.
I assume your changed the below component:
25693704-zbtre13rzitqz5mqvrpod1im-1-0.jpg At the ends of the plastic tubing are plastic push pull connectors. If the tubing is not properly seated and locked into the connector you will have a leak.
You may also have a crack in the connecting tubing from the water tank.
When you use your water dispenser, the water dispenser solenoid valve allows 65 PSI water pressure into the plastic tubing line, where if you have a bad connector or a crack in the line will cause a leak.
The is a plastic cap on the top of the above component.
1.) Put your fingers behind the above component where the tubing goes into the plastic mounting head. More often than not you can get bad parts
2.) Have someone push the water dispenser lever. Observe if water is running down the plastic tubing or if your fingers are getting wet.
May 13, 2015 | Kenmore Refrigerators
I have a kenmore coldspot model 106.53532300 and the water will not dispense from the door the icemaker is working just can't get water from the door...really miss it! Can anyone tell me what to do?!...
Hello Ray;
Ok, It may have been the water bottle. But, you have an old unit.
So, lets check it out once more.
1.) After time, from the heat, the plastic tubing for both your water lines to the water dispenser and ice maker will dry rot and crack.
Check: Pull your unit out. Have someone draw a glass of water from the water dispenser, while observing in the back both the water supply valve and the larger plastic tubing going to the water dispenser. Is there a leak when pressurized?
2.) Wait for when your ice maker fills and observe the smaller plastic tubing. Does it leak under pressure.
kenmore-coldspot-model-106-53532300-q5zw2lslmquh13tixvlr3ryr-3-0.jpg Part Number: Substitution: 4387492 Cost: $10.00
3.) Drain Pan - This too will crack over time do to heat. Pull your unit out so you can get behind it. Remove the lower back cover.. There are about 8 screws easily removed. Observe the drain tube from the under body of your refrigerator and the black drain pan where it empties. Observe around the drain pan. Are there and brown or dark stains on the floor? If so, then you have a cracked drain pan.
Repair: Unplug the refrigerator. The compressor and surrounding copper tubing prevent you from replacing the pan. When I was in the field, I would take duct tape and seal the cracked area. Then, I would cover the duct tape and surrounding area with a high temp silicone adhesive.
Mar 19, 2015 | Kenmore Refrigerators
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
Dec 12, 2012 | Refrigerators
JSI-26 icemaker leaking water
You're ice maker is located on the left hand side of the freezer, if I'm correct.
Look to the back of the freezer slightly above the ice maker and you will see what they call the fill tube. Chances are ice has formed inside and when the ice maker goes to fill water sprays instead of flows out. In some models you can take the fill tube out from the back by removing two screws that hold it in, located at the upper right side if your behind it, and some you may have to pull out from inside.
May 07, 2012 | Kenmore 21.9 cu. ft. Side-By-Side...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
I have a side by side GE refrigerator model # PSC25MSSA. The ice dispencer recently started to leak water, after producing ice. Water is frozen as it's leaking from the ice tray and forming icicles. What...
You need to replace the ice maker. There is a updated ice-maker that replaces the older models. Here is a link to the part you need and it comes with the instructions.
Happy Holidays The FixYa Team
Dec 23, 2010 | GE PSC25MSS Stainless Steel Side by Side...
Kenmore 10670187000 Refrigerator. freezer filling with water/ice
You pull it out from inside the freezer but I would try melting any ice that may be stopping it up first with a hairdryer. The water inlet valve on the back of fridge is probably leaking and when the water gets to to fill tube it freezes and partially blocks the tube causing it to spray out. Disconnect the line coming out of the water inlet valve to see if it has a slow leak. You may need to replace the valve.
Sep 03, 2009 | Refrigerators
GE refrigerator Leaks in back when trying to use water dispenser
That tube needs to be replaced or repaired. It connects to the electric valve with a compression type fitting.
May 26, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Water dispenser is not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
