Question about Intel Motherboard
Driver on MB
I need driver on MB -----Shuttle AV40S v3.1 (5 PCI, 1 AGP, 1 CNR, 3 DIMM, Audio),
VIA VT8753A Apollo P4X266A
  • 1 more comment
  • Nursultan Nugmanov Apr 10, 2008
    Very-very thankyou
    my name is Nursultan, I am from Kazakhstan
  • Anonymous May 03, 2008
    adfadf
  • Anonymous Mar 02, 2009
    keyboard not connect
  • 472 Answers
You should be able to locate your drivers HERE
Hope that helps =)
Posted on Apr 10, 2008
I need the link to down load the drivers of the motherboard MSI k8T NEO2-F V2.0
Posted on Jul 28, 2008
Drivers ECS M909G
Posted on Jun 11, 2008
My mother board cd is not supported my mercury motherborat as i have no listen to music pls help me.
From the motherboard type given, below are the technical specifications:
  • General Features:
  • VIA P4M800/VT8237R chipset
  • Socket 775
  • mATX form factor
  • Version 1.0
  • Supports up to 2 GB 2.5V DDR SDRAMs (DDR400/333/266)
  • Embedded UniChrome Graphics with 64 MB shared memory
  • Realtek ALC655 6-channel Audio Codec
  • Compliant with AC'97 2.3 specifications
  • VIA VT6103L 10/100 Mbps Fast Ethernet PHY
  • Two (2) SATA/150 (Serial ATA) connectors
  • Two (2) UDMA/133/100/66 IDE controllers
  • One (1) Floppy controller
  • Expansion Slots:
  • One (1) AGP Ultra slot
  • One (1) CNR slot
  • Three (3) PCI slots
  • Two (2) 184-pin DIMM sockets
  • I/O Ports:
  • Two (2) PS/2 ports
  • One (1) 9-pin Serial port
  • One (1) 15-pin VGA port
  • ONe (1) 25-pin Parallel port
  • Four (4) USB 2.0 rear ports
  • Two (2) USB 2.0 ports via header
  • One (1) RJ-45 Ethernet port
  • Line-in, line-out and microphone jacks
  • BIOS Features:
  • AMI 4Mb Flash ROM
  • Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
  • Full support for ACPI revision 1.0 specification
  • Supported Processors:
  • Intel Pentium 4 and Celeron D processors with Hyper-Threading Technology
  • Socket 775
  • 800/533 MHz FSB (Front Side Bus)
  • Regulatory Approvals:
  • FCC
  • CE
  • C-Tick
Package Includes:
  • Mercury P4VM800M7 VIA K8M800 Socket 775 mATX Motherboard
  • Manual
  • Driver CD
  • SATA cable
  • IDE cable
  • Floppy cable
  • SATA to 4-pin power cable
  • I/O shield
You will therefore need drivers for the following devices to utilize the multimedia functions of your system:
Download the Realtek ALC655 AC97 Audio Drivers from here(Link:http://download.cnet.com/Audio-Realtek-ALC655-AC-97-AUDIO/3000-2110_4-168843.html?tag=contentMain;overviewHead) and the Embedded UniChrome Graphics drivers from here(Link:http://download.cnet.com/VIA-S3G-UniChrome-Pro-IGP/3000-2108_4-65294.html).
Have a good time ahead.
Feb 03, 2011 | Mercury P4VM800M7 Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
The sound on my L7VMM2 motherboard is not working.
First of all which operating system is on the machine?
Secondly have you been into the BIOS to see if the on-board has been disabled. To get into the BIOS restart the computer and press either the Del or Esc key to access the BIOS.
Also go to device manager and see if the audio has been disabled from there.
If you have installed Windows 7 or Vista then there could be a chance that the motherboard drivers are not designed for the operating system. If that's the case then no driver will work.
You would have to manually search the internet for someone who may have found a compatible driver.
Regards.
Jul 22, 2010 | EliteGroup Computers & Internet
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
Need VIA AC'97 Enhanced Audio Controller Driver
You probably need the M/soft UAA drivers first download and install them
Then go to device drivers right click driver with yellow mark on it and upgrade driver should go on net and find and install driver
Oct 06, 2008 | Computers & Internet
MV43V motherboard by shuttle
Here are your MB specs:
MV43V/N - Supports Socket 478 Intel Pentium 4, Celeron with 400/.533 MHz FSB
- VIA P4M266A + VT8235 Chipsets
- DDR 200/266 SDRAM, 2 x 184 – pin DIMM, Up to 2 GB
- 2 x ATA 133
- 4 X AGP device, 2 PCI slots, 1 CNR slot
- Onboard AC97 audio two channels
- Onboard S3 Pro-Savage 3D Graphics
- Onboard VIA VT6103 10/100 Fast Ethernet (MV43VN only)
- 6x USB 2.0
- Micro ATX Form Factor
The your motherboard has an ethernet adapter all you need to do is download the drivers for the ethernet adapter and install them. here is the link : http://members.driverguide.com/driver/detail.php?driverid=206328 do a free subscription first. cheers
T
YE
Feb 16, 2008 | Shuttle MV43N Motherboard
Intel Motherboard Logo
517 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
