Question about Ruud UBHC Air Conditioner
Too much condensation
There is too much condensation leaking from ac unit
    Scholar:
  • 45 Answers
I have never heard of "too much" condensation. The condensation is the the moisture that is being removed from the home. If the home is very humid and its common for alot of condesation to be removed from the coil. As long as the coil is not freezing up, you are good to go.
Posted on Jun 07, 2010
What is causing water to leak down onto the floorboard of my 2004 Mazda 6 when I have AC on?
this will be condensate from the fins of the ac evaporator in the car and is leaking onto the floor because the drain on the unit is blocked either in the hose or at the bottom of the ac box
Aug 24, 2014 | 2004 Mazda 6 Wagon
Where is the ac unit on 2001 lasabre custom?
Where is the leak on the radiator? (front, side, top, bottom...)
My guess is that it might have also caused a leak in the condenser, or the lines going to the condenser. The lines are connected on the right side of the condenser, which is mounted right in front of the radiator.
Jun 25, 2014 | 2001 Buick LeSabre
I have a Kenmore Portable ac unit and its leaking from the back in the middle of the vent. I drained the unit,but it starts leaking again within minutes. Is there something wrong or could it just be too...
All portables, alllll, you have to put unit in
window with a slight tilt, as the unit runs
it creates condensation that condensation
is the water leaking out the back it's supposed
to do that, I have seen people hook a hose up
an let it drain in a bucket.
even your car a/c leaks water
Jun 03, 2014 | Heating & Cooling
AC unit is leaking
The drain tube is pluged take the hose off at the unit try blowing in it chances are its pluged and the condensation can't drain
Jun 27, 2013 | Heating & Cooling
Why is Portable AC is leaking?
Condensate should be directed outside. The condensate collection device may be plugged, broken, missing or not draining (overflowing)
Sep 12, 2012 | De'Longhi Delongi PACA120E 12,000 BTU A...
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
Jul 11, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
My rudd uaka 037JAZ leaks, like to replace just AC and not coil and furnace motor. Replacement suggestion for this unit? Homeowener George
Hello, it depends where the unit is leaking from, if it is leaking from the condensing unit then you can just replace the condenser, however if it is leaking from the evaporator coil then you will need to replace the evaporater. As far as brand for replacement I like rheem equipment. The best thing to do is have a hvac technician come out and give you a estimate on a new AC and then you can make a decision.
Feb 21, 2011 | Ruud UAKA037 Air Conditioner
MY split ac is leaking water from the wall unit, it has been doin
Usually an AC unit builds up condensation. If you have a drain hoole or hose that is clogged up therefore not allowing the build up to drain off it will spill over the top of whatever housing the condensation goes into. If you can look for that issue first.
Aug 03, 2009 | GE Quiet-Aire Ductless Split System Air...
Dometic ac
remove the lower assembly and tighten the bolts that hold ac down to coach or pull shroud and check to make sure unit is not frezing up due to dirt
Jul 13, 2008 | Dometic 57915531 Air Conditioner
Ruud UBHC Air Conditioner Logo
516 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
