Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
My model AM-50bae ice machine has water in the storage bin,what can I do?
    Novelist:
  • 117 Answers
Check the bottom of the bin for a drain spout. The drain line may be clogged allowing the water to build-up in the bottom.
If the water is coming down from the ice machine itself, you will need to open up the machine and look inside. Check to ensure the cube guides have not come out of place, that the sump is not overflowing with water, and that there are no loose, leaking, disconnected, or busted hoses.
Posted on Jun 07, 2010
I have a Hoshizaki AM-50BAE and it suddenly stopped making ice and all the ice melted away. Can it be fixed? What might be wrong?
the wiring diagram shows that if the bin thermostat goes bad, it will not send power to the control board and noting will run. look for that first, could be a simple fix.
Mar 29, 2015 | Hoshizaki Freezers
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
No power. checked fuse box. Tried reset. no luck.
If you are sure you have power to the wiring of the machine, check the bin control. If it's frozen in the open position (electrically) or the capillary tube that connects it to the sensing bulb that sets inside the storage bin is cracked, it will keep the machine off.
Jun 18, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
My ice machine does not make enough ice
Check the water filters first. Then check the condenser coils for dust and dirt. Determine which way the air goes thru the condenser coils and check on the side the air goes into. There are coil cleaning sprays that work good. If it is still slow, it may need gas. That will require a service call from a technician.
May 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
No ice saved
If it's makes a good slab of ice the only reason it would melt would be a drain blockage holding water in the bottom of the unit or the water pan overflowing into the bin when it fills up. If you check the slab when it falls on the cutter and see a hollow looking spot in the middle you may have an evapoator leak. Yhis would require a service tech to repair.
Apr 22, 2008 | Freezers
Ice maker leaks into the ice storage bin
turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
Jan 11, 2008 | Freezers
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
205 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
0duro
Level 1 Expert
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
