Question about Craftsman 17765 Canister Wet/Dry Vacuum
I was using vac to **** up water after pressure washing my pool deck. The canister was about 1/2 full and getting heavy to move so I decided to empty it. (It was working just fine up to this point) I took the top off and carried the canister to the yard to empty it. After putting it back together, it won't come back on. Thinking it might need to dry out (?!?!?) I let it sit for 5 days ... still nothing. Any suggestions or advice? Thank you in advance.
  • Craftsman Master
  • 10,074 Answers
Is the ball stuck at the top inside it??
Posted on Jun 17, 2017
5 Suggested Answers
SOURCE: craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
Posted on Feb 27, 2008
  • 1990 Answers
SOURCE: Craftman Canister Wet/Dry vac- Motor just stopped working
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
  • 867 Answers
SOURCE: Wet/Dry Vac Leaking
are you using a water , foam material filter?
Posted on Aug 01, 2009
  • 3053 Answers
SOURCE: My Craftsman wet/dry vac stopped
For some reason, sounds like your contacts in motor got wet. Now I know this sounds funny with a product that is called wet and dry. I believe if you open it up, let it dry good, of course around motor( use hair dyer to speed process) it should dry out and most likely start working after contacts dry out. OH , don't forget to check breaker that shop vac is plugged in, uncase you tripped breaker on wall plug in circuit, and FINALLY , see if there is a normally red reset button on shop vac motor, it might have tripped. Please let me know if I helped, if so please respond with thumbs up and short comment, it helps me and other viewers. Thanks mike from fixya
Posted on Jun 17, 2011
Release button to empty cylinder wont work cant get it off manually
Hello, the canister empty function works by pulling a long plastic rod that moves the catch on the bottom access door. It sounds like either the puller is stuck or that the rod may be broken. If the puller does move upward when pulled, then the later in most likely. You can check by removing the Torque screws and pulling the top section off very gently, because the canister really needs to be opened and removed first, do this outside to avoid a dirt spill in the house, either way I would look for a used canister from another machine, which is really a much cheaper and less dirty option.
Mar 07, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Why is dirty water shooting out of my wet/dry vacuum
It's full, needs emptied. You have to keep the sponge like filter in to collect the water mist.
Apr 13, 2014 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
I've been using a small shop vac in the seller to vacuum up dust, sawdust etc. I have emptied the inside and the filter looks laden with dust. It does not "****" any longer. What is wrong and what do I do...
you have to clean the filter too. Use an air hose to clean it or brush it off with a stiff brush or you can wash it if it isn't paper. As a last resort you can get a new one.
Oct 04, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Kenmore vac won't shut off, blowing heavy air from vent
For the stack of problems you have, it sounds like it be best for you to ditch it and get a new vacuum. The heavy problem sounds like a motor issue. The burning smell is most likely from the belt being loose on the power head.
Economically, you should just get a new one instead of replacing the whole system guts
Aug 14, 2009 | Kenmore 25512/ 25513 Progressive Canister...
ok . i may have read you post wrong but i think you want the vacuum to empty itself ? i never heard of any vacuum emptying itself ......... the water or dirt goes into the canaster . when full remove the top and dump the bin . some than a drain plug you take out when your over a floor drain or outside ........ if this answer helped please rate 3 or 4 this high rateing will keep me in the paid answer department thanks you ..........if i misunderstood your post i am sorry , just leave a comment i will get it and try to help
Apr 03, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
How to connect the vacuum system in the swwiming pool
Generic problem for all Vacuums
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Craftsman 17765 Canister Wet/Dry Vacuum Logo
Top Craftsman Vacuums Experts
Tim Doolittle
Tim Doolittle
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
