Question about Logitech Cordless Optical Mouse for Notebook 931151-0403
Cordless Mouse Dead
Whe I press the connect buttons on both the mouse and the base, the light does not come on, and the cursor does not move on the screen. Has my mouse died? Richard G
How old is this mouse and was it used often?
It may just have a flat battery, Does it use rechargables? can you test the Battery? Did the mouse undergo a BIG DROP??? C
Posted on May 28, 2008
Keyboard does not type
If all the keys on the keyboard have stopped functioning follow the instructions below to reconnect the keyboard.
This problem is likely to be a lost connection. The connection between the mouse and the USB mini-receiver or the keyboard and the USB mini-receiver can be lost due to several reasons such as:
  • Low batteries
  • Moving the USB mini-receiver from one USB port to another
  • Moving the USB mini-receiver to another computer
  • Plugging the USB mini-receiver into a USB hub or other unsupported device such as a KVM switch (your USB mini-receiver must be plugged directly into your computer)
  • Using your cordless mouse/keyboard on metal surfaces
  • Radio frequency (RF) interference of more powerful wireless devices such as:
    • Wireless speakers
    • Computer power supplies
    • Monitors
    • Cellular telephones
    • Garage door openers
Eliminate any problem sources mentioned above that might be affecting your devices.
Follow the procedures below to reconnect your mouse and keyboard.
  1. Make sure the USB mini-receiver is directly and securely plugged into a working USB port on your computer.
  2. Make sure the mouse is turned on. The on/off indicator on the bottom of the mouse should be green. If the on/off indicator is not illuminated, press and hold the red connect button on the bottom of the mouse until the on/off indicator is green.
    On / Off Indicator
  3. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your mouse. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  4. Quickly press the red connect button on the bottom of the mouse for 1 second, then release it. The power indicator will flash briefly and then turn green. The mouse is now connected to the receiver.
    Red Connect Button NOTE: Holding down the red button on the mouse for more than 2 seconds may cause your mouse to turn off instead of connecting. If this occurs, start again at step number 2.
  5. Move your mouse to see if the cursor moves. If the cursor follows the mouse movements, your mouse is now connected.
  6. Press and release the red connect button on the underside of the USB mini-receiver. This will broadcast a signal to your keyboard. This broadcast will last only a few seconds, so you must perform the next step quickly.
    Red Connect Button
  7. Quickly press and release the red connect button on the underside of the keyboard.
    Keyboard Connect Button
  8. You will hear a short beep. The keyboard is now connected to the receiver.
  9. Test your keyboard to see if it is working. If the mouse now works but the keyboard still does not, see Knowledge Base article 9144.
Dec 14, 2010 | Logitech Cordless Desktop MX3200 Laser...
I can't move the cursor with my cordless mouse - New batteries have been replaced.
You may need to re-connect it. Have a look for a little button on the bottom of the mouse... and a little button on the reciever stick that pkugs into the computer, press them one after the other and see what you get? Hope this 'Helped?
Sep 26, 2010 | Logitech Cordless Mouse
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
Mouse does not work
Be sure your mouse is plugged in. If this is a wireless mouse verify the receiver is plugged in, and if your mouse and/or receiver have a "connect" button push it on one or both of them.
If this fails, unplug the mouse or receiver and plug it back in.
If None of the above work, restart your computer, and if that fails your mouse is likely dead.
May 20, 2009 | Logitech Cordless Mouse
The cursor on my laser wireless mouse won't move
You need to sync the mouse with the USB receiver. They'll be a similar button on the receiver. Push both at the same time.
Apr 07, 2009 | HP Wireless Optical Mouse
I have changed batteries, still not cursor moving. are there batteries in the transeiver as well?
check if you find a little button under the mouse, press that. also if you find a button on the transeiver press that first then press the little button on the mouse. it have lost the connection and need to reconnect.
Feb 23, 2009 | Logitech Cordless Mouse
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Is the batteries good. If so try,
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 08, 2008 | Logitech Wheel Mouse Optical
Im trying to install the wireless mouse. computer detects new hardware when started up but the mouse wont move the cursor
check the switch in the bottom of your mouse that its set ON and if it has a connect button press that. some models do some dont. not sure about yours.
Apr 29, 2008 | Logitech LX5 Cordless Optical Mouse
I got 2 logitech wireless mice in same desk, because I dont have anywhere else to place them, and they interference with each other...How can I change frequencies? Please help Thanks
This is in the logitech knowledge base.
Question: ''When I move my cordless mouse, it moves the cursor on the system next to me. What should I do?''
Answer: ''This is called ''Cross talk'' and is characterized by one cordless device controlling the cursor or keyboard input of another device connected to a different computer. To avoid possible interference, try to keep the distance between systems at least 10 feet. Also, moving the mouse closer or further away to the receiver can also improve transmission and performance. If the above fails, try pressing and holding the ''Connect'' button on the receiver for 10 seconds. This will reset the receiver's connection information and allow you to do a first time connection with the receiver and mouse or keyboard. After holding the Connect button for 10 seconds, then press the Connect/Channel button on the bottom of the mouse to synchronize it with the receiver. If you have a cordless keyboard instead of, or in addition to, a cordless mouse, press the ''Connect'' button of the receiver again, then press the ''Connect/Channel'' button on the Keyboard. Perform these same steps on any other Logitech cordless devices in the area that are experiencing cross talk. Another step that can be tried is to remove the batteries for 15 minutes. Then re-insert them and boot the computer up. It is important that during this time, you do not press the connect button on the receiver or keyboard of the other cordless desktop system.
I could not find anything on mouse crosstalk in the Microsoft knowledge base. Perhaps the problem is not so common for MS mice because of their more limited range.
Buying a new mouse was suggested. This may or may not work if you bought a new Logitech mouse, as it could wind up on the same troublesome frequency. Of course, if you replaced the Logitech mouse with a Microsoft mouse, their limited ranges might eleminate the problem, even if they used the same frequency.
Apr 22, 2008 | Computers & Internet
Cordless mouse cursor frozen
it is absolutely broken even u can click right and left but the red light is off it is like half dead machine, i advise u get another one...
Mar 03, 2008 | Logitech Cordless Optical Mouse for...
Logitech Cordless Optical Mouse for Notebook 931151-0403 Logo
69 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
