Question about Acer Aspire 3680 Laptop
Backlight in monitor not working
I have acer aspire 5920 and it has been working fine however this morning the light on monitor is not working it is still functioning however is dark why is this? and how do i fix it?
    Sergeant:
    Champion:
  • 293 Answers
Try to press fn + any function key that has the sun logo or to bright your monitor.
if that doesn't work bring your laptop at the service center because the lcd is having a problem
Posted on Apr 10, 2008
How to fix acer aspire 5920 left side key board ?
Sounds like the keyboard is faulty. Replace the keyboard.
Jul 29, 2015 | Computers & Internet
Hi, I have acer aspire 5520,2 Gb RAM... When I turn on my acer,everithing works just fine,exept monitor,it remains black,When I try ecternal monitor,it works fine,windows wors fine to,everithing but the...
Aspire 5520 has LCD Display. The screen displays becomes dark/ dim if there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. These parts are inside the LCD screen. Either of the parts may be faulty or in some rare cases both. Also, the video data cable may be loose or faulty, which can be identified only after opening the top cover.
So, my advice is that you get it properly checked by any professional for replacement of Inverter or CCFL.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 22, 2011 | Acer Aspire 5520-5579 Notebook
My acer aspire 6530 boots up fine but I get nothing on my screen. It's just black, no light at all. When I plug it into an external monitor it works fine and in fact I'm using the acer right now but with...
To check whether the LCD screen itself if the issue or the backlight or inverter. You have to carefully look in the screen and see if you see anything on it. It would be extremely dim but try white background and black screen. If you see something in it, then most probably it's either the backlight or the inverter. For that you need to buy those from the market and install it, OR IF YOU ARE NOT A TECH GENIUS I WOULD RECOMMEND YOU TAKE IT TO A DEALER IF ITS IN WARRANTY TAKE IT TO ACER THEY SHOULD FIX IT FOR FREE.(I dont know the rules of Acer, but most companies fix that for free)
Nov 01, 2010 | Acer Aspire 6530-5143 Notebook PC
Good Morning: I have an Acer Aspire 5920
As by your description, the FN F7 key combo did not solve the problem. Please restart the machine , press F8 then select from the list "Safe mode" then press enter. Then see how the Touch pad reacts in Safe mode. If it works perfectly in safe mode, we can assume you have a software problem that is preventing it from working in normal windows mode.
Please download and install the latest BIOS for your machine. The E525 has a issue where the TP just stops working, upgrading the BIOS solves the issue on the E525...
Acer Aspire 5920 3813 BIOS
Please install one of these drivers for the desired Operating system...
Acer Synaptics Device Driver Windows XP
Acer Synaptics Device Driver Windows Vista
Acer Synaptics Device Driver Windows 7
May 13, 2010 | Acer Computers & Internet
Acer Aspire 5920 won't turn on
check the ram chips havent come loose, i had this problem with an acer aspire 5315 (fixed myself). if that doesn't work, check the lcd cable
Dec 26, 2009 | Acer Aspire 5920-6727 Notebook
Aser Aspire 5920 Will Not Switch On
it must b some problem with the RAM......get the ram changed ...den it will work fine
Sep 02, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Crystal eye web cam not found on aspire 5920
Acer aspire has inbuilt web camera and therefore will work only if the correct drivers are installed. Please uninstall the drivers first from control/panel/add remove programs. Next reboot the system and then go ahead with the installation.
http://www.laptops-drivers.com/acer-notebooks/download-drivers-acer-aspire-5920-notebooks.html
Thank You for using Fixya.com
Jul 26, 2009 | Acer Aspire 5920-6727 Notebook
Hi.. I am suffering flickering problem with my Acer Aspire 5920.
This is often a problem with the backlight on the LCD panel. If you gently tap the side of the LCD does it flicker more? If it does, then there is a loose connection in the LCD panel, and you might be able to get a comptuer shop to fix it, but it usually is expensive. If you don't mind using the laptop as a desktop, then get an LCD monitor and a USB keyboard and mouse, and you can use it as a desktop.
Jan 30, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 3680 Laptop Logo
249 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
