Question about Garden
When the cord is pulled, it does not catch properly, I have removed the assaembly and the thing that is supposed to be turned by the cord is worn on the top edge so the cord is not able to grip it. I need another one of these parts. But I don't know what it's called or where to get it!!
  • 177 Answers
Maybe if you tall us what model and machine someone will be able to help
Posted on Jun 07, 2010
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
Sears craftsman manuals?
You can't get sears manuals. If you remove the recoil assembly and turn it over you will be able to turn it. If the spring catches and starts to wind then you know your spring is good and you don't have to replace it. If it doesn't spring when wound replace spring. When ready turn till spring is fully wound ( can't wind anymore without force) then back it off until the rope holes line up. Install rope and handle and retract slowly. Pull handle a few times to make sure its not sticking and retracts properly. Reinstall on engine
Jul 27, 2014 | Garden
HUSQVARNA 326E PULL CORD WANT TURN SHAFT
could be the pawl catch on the crank shaft is not working properly, if this is an easy start model, there are two springs and two pulleys to inspect. usually second spring is the problem.
Jul 25, 2014 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Pull cord get tuck
If I understand properly, it sounds like the dogs on the recoil mechanism are worn. They are designed to engage with centrifugal force when you pull the cord. Make sure they are coming out when you pull the cord, you have to remove the housing to do this and make sure the dogs aren't worn. Also check the plate they engage onto on the flywheel and make sure it is tight and not worn/
Aug 03, 2013 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
My left hand side door cord has broken, how much of the machine do I need to take apart? do I need to pull the machine from under the counter top?
Yes you will have to move from under worktop and then remove the side panel that the cord has broken.It may be worth checking the other cord and replacing both if worn.Also check if something is catching to cause the cord to break.
Hope this helped.
May 16, 2010 | Baumatic 23 in. BDW9 Built-in Dishwasher
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
TB144 pull cord does not catch, pulls free--no start
yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
May 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
