Question about HP vs15 15"LCD Flat Panel Monitor
OSD lock on my monitor "OSD LOCK" is continuously blinking all the time.. i am not getting a solution to solve it..
  • 1 more comment
  • Anonymous Jun 13, 2008
    osd lock out
  • cristian1986 Aug 25, 2008
    on the monitor i got this massege OSD LOCKED and is flashing i try to press menu for 10 minutes but it does not work.
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    Your suppose to only hold the menu button down for 10 SECONDS.
    RDO
    New Friend:
  • 62 Answers
1. press the Menu butten 15 Secunds.
2. replaced the control panel micro switchs.
3. changa the 7805 reguletor near to proccer
Posted on Nov 22, 2008
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
I am getting many times osd lock problem i am getting irritating so please give solution for unlock the osk lock on monitor.... or sometimes repeatedly blinking the main menu on the...
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Nov 26, 2010 | ViewSonic E70f 17" CRT Monitor
OSD lock flashing on monitor
To remove the OSD lock, kindly use the steps as shown in the attached image:
Hope this solves your problem. Thanks for using FixYa.
Jun 14, 2010 | ViewSonic E70f (White) 17 in.CRT...
Compaq FP5315 monitor with OSD Lock out
Here is the tip to solve your problem. Hope this might be helpful to you.
OSD Lock—The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock” displays for five seconds.
❏If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
❏If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Aug 07, 2009 | Philips 170S7FS 17" LCD Monitor
OSd lock keeps on poping up on my screen, i ihave viewsonic monitor. how can i solve this problem?
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 28, 2009 | ViewSonic E70f 17" CRT Monitor
Osd lock
Dear srinivasvodn,
Press the menu button of your monitor for a wile OSD lock will unlock.
Aug 05, 2008 | ViewSonic 17" CRT Monitor
Problem in TFT
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
115 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
